Estimated RPM's where power should fall off at
Mods:2000 JDM GSR Longblock:
81.25mm block w/ a 89.00mm stroke (LS crank)
Oversized ITR pistons (lil bigger than the stock 5.96 displacement )
ARP Rod Bolt studs
ACP Bearing set
OEM LS Rods
Head shaved .25 thousandths
3 angle valvejob
ITR cams (never buy these from the dealer )
Skunk2 Intake Manifold
H22 Throttlebody
RC 310cc injectors
ANR Custom Street Header w/ street collector (went cheap on it )
full 2 1/2 pipng back to 3inch Apexi N1 muffler
Engine Management:
Harness Stunna Conversion Harness
OBD1 chipped P28 w/ Skunk2 program
Apexi VAFCII (I'm still half rice)
Transmission:
B16 Tranny
ACT clutch system
Suspension:
Spoon Sport Progressive springs
Tokico Blues (needs to be ordered)
Im thinkin the power with a close to stock valvetrain should fall off a lil bit over 8 grand....
anyone else?
ARP Rod Bolt studs
ACP Bearing set
OEM LS Rods
3 angle valvejob
H22 Throttlebody
RC 310cc injectors
Engine Management:
Transmission:
B16 Tranny
ACT clutch system
Suspension:
anyone else?
A dyno will answer your question better than any of us could.
Those tokico blues should make it hold power well past 9k though.
AllMotor12s
Nov 15, 2005 06:25 PM
1weakSi
Dec 27, 2004 08:01 AM
tnsxsear1
12
Apr 12, 2004 06:08 PM
anyway......Im thinkin the motor should make power up to the 85-9000rpm range
