dc5 header ques and need bottom half of downpipe
dc5 header ques and need bottom half of downpipe what do ineed to install the dc5 header into my rsx s anything special
aslo i need the bottom halfoi d downpipe if any body has it
the header that you have should bolt rite up to the stock rsx downpipe if you want better power gains go ahead with a race header DC makes a good one and JR does also the JR comes with a test pipe that removes the cat
do you mean you have the DC5R 4-2 header w/o the 2-1 downpipe?
i'm still not sure what you're installing. you already have your oem header and downpipe....
if you're installing a shorty header, it bolts up to the block and your oem downpipe
if you're installing a race header, you don't need a downpipe or a cat cause the race header replaces all of that.
i have just the top part of the typer header but i need the bottom part to put it on my rsx s also what other parts am i gone need to install this cause i got the front knuckes and sway bar from the dc5 also that i will sell if i dont need to install header cause i heard it hits somewhere also what abbout codes after installation thanks guys for patience i write late when i get home so iam tired
EM2ABOO
Honda Civic (2001 - 2005)
Oct 25, 2009 10:07 AM
HondaHeddie
Nov 20, 2006 08:08 AM
