Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
:best sized spacer and studs to use for autox and daily driving??:
Old Dec 26, 2004 | 08:09 AM
spock_rocker's Avatar
memoryFAB.com representative
Default :best sized spacer and studs to use for autox and daily driving??:
ive done some searching and im just kinda confused. i plan on getting a set of slips(15x7) for next season, cause well im poor. they come in a 40mm only. and i wanted a much lower offset. i was thinking a +32mm would be good. so what extended studs and and spacers would be recommended and any other advise you could give me. thanxx
Old Dec 26, 2004 | 08:15 AM
vbspec's Avatar
Default Re: :best sized spacer and studs to use for autox and daily driving??: (spock_rocker)
What car are you putting them on and what tire are you planning on running.
Old Dec 26, 2004 | 09:52 AM
Default Re: :best sized spacer and studs to use for autox and daily driving??: (vbspec)
eg hatch, ill most likely be running a 205/50/15.. the new azenis depending on price... or if you would recommend something different
Old Dec 26, 2004 | 10:31 AM
.RJ's Avatar
.RJ
+40mm offset is just fine
Old Dec 26, 2004 | 11:01 AM
Default Re: :best sized spacer and studs to use for autox and daily driving??: (.RJ)
ive just been told that there are advantages to running spacers...
Old Dec 26, 2004 | 11:20 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">ive just been told that there are advantages to running spacers... </TD></TR></TABLE>
No advantage if you have the proper offset wheels to start with
Old Dec 26, 2004 | 04:03 PM
00R101's Avatar
RJ is correct. As a matter of fact there is a disadvantage to spacers - you will most likely need longer studs. The only reason to use spacers is if you cannot get wheels in the offset you want.
You will see many stock class autocrossers using spacers to get the extra 1/4" track that they are allowed by the ruleset out of their stock wheels. But that is an exceptional case brought on by the rules and not by good engineering.
I would rather have a wheel with a 30mm offset then a 40mm offset wheel and a 10mm spacer; wouldn't you?
Old Dec 26, 2004 | 04:10 PM
-=M=-'s Avatar
Default Re: :best sized spacer and studs to use for autox and daily driving??: (00R101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">+40mm offset is just fine</TD></TR></TABLE>
yup, or you can get the Rota Grid +38
Old Dec 27, 2004 | 09:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00R101 &raquo;</TD></TR><TR><TD CLASS="quote">I would rather have a wheel with a 30mm offset then a 40mm offset wheel and a 10mm spacer; wouldn't you?</TD></TR></TABLE>
thats what im getting at. i wanted to run a 32mm wheel but in order to go that and run slips ill need longer studs and a 8mm spacer.
Old Dec 27, 2004 | 09:41 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote"> i wanted to run a 32mm wheel </TD></TR></TABLE>
Why? It will rub... you'll need to roll fenders quite a bit.
Old Dec 27, 2004 | 09:50 AM
JeffS's Avatar
I'd be interesting in hearing what you think they are.
Old Dec 27, 2004 | 10:29 AM
vbspec's Avatar
thats what im getting at. i wanted to run a 32mm wheel but in order to go that and run slips ill need longer studs and a 8mm spacer. </TD></TR></TABLE>
A +32 mm offset wheel and a 8mm spacer makes the wheel +24mm off set not +40 like you think...
Read this http://www.discounttire.com/dt...s.jsp
Old Dec 27, 2004 | 11:16 AM
well... the advantages are ive heard are better for grip and such, wider stance the better grip. what i was saying was.. slipstreams only come in a +40mm offset and i would like to run a +32mm offset... so in order to do that i know im gonna have to run an 8mm spacer and extended studs. and im prepared to roll the fenders.
Old Dec 27, 2004 | 12:38 PM
slammed_93_hatch's Avatar
Why? It will rub... you'll need to roll fenders quite a bit.</TD></TR></TABLE>
roll the fender some yes, it wont rub if you roll you fenders enough and stay at a decent height.
I ran a +32 offset wheel with a 205-50-15 and i had no problems rubing.
As far as studs go i like ARP kinda pricy though, or Doorman studs (most auto parts stores carry them) for a certian year cavalier and for a certian year TL or RL or CL. there is a great thread in this forum about studs. Easiest way to go would be ARP.
as fair as spacers im not sure
Old Dec 27, 2004 | 01:16 PM
.RJ's Avatar
.RJ
Default Re: :best sized spacer and studs to use for autox and daily driving??: (slammed_93_hatch)
Rear TL studs are 10mm longer...... there's a thread somewheres aboot it w/ part #'s.
Old Dec 27, 2004 | 02:25 PM
can i run rear TL studs all the way around? and have enough thread left for an 8mm spacer maybe a 10mm if i wanted to??
Old Dec 27, 2004 | 02:31 PM
.RJ's Avatar
.RJ
The studs in question are 10mm longer than the stock integra/civic studs.
Old Dec 27, 2004 | 08:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">can i run rear TL studs all the way around? and have enough thread left for an 8mm spacer maybe a 10mm if i wanted to?? </TD></TR></TABLE>
correct no more then 10mm though
juall
Dec 30, 2007 07:35 PM
turbo95eg6
Sep 4, 2007 04:36 PM
meanEG
Jun 5, 2007 09:41 AM
buyer
13
Feb 6, 2006 05:33 PM
Tad
May 11, 2005 08:06 AM
