Stock GSR block, ITR head milled .020, stock ITR IM/TB, GSR cams, how will it run?
Old Dec 25, 2004 | 10:38 PM
rodimus's Avatar
Default Stock GSR block, ITR head milled .020, stock ITR IM/TB, GSR cams, how will it run?
SETUP
block:
2000 stock gsr
head:
alaniz valvetrain (same as portflow)
stock gsr cams
stock ITR intake manifold/ITR throttle body
J's racing intake
ecu:
obd1 P72 chipped w/fugen program (vtec 4400, redline 9k?)
other notables:
itr tranny, 6 puck sprung hub clutch, itr flywheel, no ps/ac, big 3 ground wire upgrade =P
my current setup is this, but with completely stock gsr top end with the j's racing intake)
HOW WILL IT RUN VERSUS MY CURRENT SETUP? any guesses or personal experiences? the head is milled so compression should be about 10.1 ..this is my daily driver so i'm curious to see if anyone has any input before i get it up and running.
Modified by EVOL at 2:29 AM 12/26/2004
Old Dec 26, 2004 | 08:42 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Stock GSR block, ITR head milled .020, stock ITR IM/TB, GSR cams, how will it run? (EVOL)
had a similar set up but with RS cams and i had 35 thou off my head with a P&P i laid 181whp on a chipped P72
Old Dec 26, 2004 | 10:16 AM
cjohnson_2's Avatar
Default Re: Stock GSR block, ITR head milled .020, stock ITR IM/TB, GSR cams, how will it run? (SnoFlake)
Id guess 170
Old Dec 27, 2004 | 02:36 PM
ALLMOTOR18's Avatar
I had the same setup, but with JDM ITR pistons and Skunk2 Stage 1 cams..
Made 188 whp / 134 tq on a Dynojet and 206 whp / 140 tq on a Clayton dyno..
lazii_boi08
Jan 16, 2011 03:49 PM
lsvtec101
Jan 13, 2009 05:37 PM
flatblack-h22
24
Sep 8, 2007 09:37 PM
PurEvl
Jul 17, 2006 02:27 PM
lrgsrhb
Feb 28, 2003 07:59 AM
