dc5 brake question agian
Old Dec 25, 2004 | 09:12 PM
MaskedAP1's Avatar
Default dc5 brake question agian
r the typeS front rotor and caliper will bolt on base ones?
TIA
Old Dec 25, 2004 | 11:45 PM
MaskedAP1's Avatar
Default Re: dc5 brake question agian (MaskedDC4)
or also need the typeS bracket since the rotor size r different?
Old Dec 27, 2004 | 06:11 AM
RacerDataDisplay's Avatar
You also need the type-s knuckles. The base has a smaller diameter rotor, so the
caliper mounts in a different location on the knuckle.
Old Dec 27, 2004 | 01:21 PM
MaskedAP1's Avatar
Default Re: dc5 brake question agian (RacerDataDisplay)
this is from clubrsx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I did this upgrade myself already.
Direct bolt on for the caliper and rotors.
You dont need anything else, though the type-S knuckle has a larger heat shield, unfortunatly you need to swap the whole knuckle for that, but its not necessary</TD></TR></TABLE>
so base knuckle should be ok with it?
TomCurllyFry
Suspension & Brakes
Nov 29, 2012 01:53 AM
Integra4lyfe069
Mar 10, 2011 08:51 AM
vti444
Sep 7, 2004 01:46 AM
Lo-Buck EF
Apr 20, 2004 10:31 AM
Understeer
Dec 15, 2003 10:26 PM
