EF reliability
Old Dec 25, 2004 | 05:21 PM
Killerrobotjews's Avatar
Default EF reliability
How reliable are civic ef's? I might be picking up this: as a first car
91 EF
Engine:
JDM B16A w/ YS1 Trans
3 inch Intake w/ Stock Air box modified (Similair to a Comptech Ice Box)
Skunk2 Intake Manifold
B&M FPR w/ Gauge
Apexi World Sport Exhaust w/ Test Pipe
Exterior:
Ground Control Coilovers
Cross Drilled front rotors
New Rear Drums
bodys got 150,000 miles on it, new engines got about 60k on it.
I need this to be reliable for getting to work, think this will be fine? anything i should have the mechanic check specifically before i buy it?
Old Dec 25, 2004 | 05:26 PM
doublethink's Avatar
Default Re: EF reliability (Killerrobotjews)
its going to explode instantly.
jk
the intake manifold is changed, make sure it idles ok.
jdm climate control, with temp thermostat dial? did he use the rest of the components so it actually works correctly?
make sure your heat and a/c work, cause its very possible he didnt do it right. usdm cars have manual cable temp system, not electric like the jdm cars.
Old Dec 25, 2004 | 05:47 PM
viper_2_4's Avatar
I would get something slower as your first car, get some experience driving (assuming you are a relatively new driver, if not ignor this) a slower car then go get something with a little quicker.....but I think it would be a reliable car....
Old Dec 25, 2004 | 05:56 PM
86si's Avatar
dude it's A Honda of course it's going to be reliable
Default Re: EF reliability (viper_2_4)
im not a new driver, been driving parents cars for 2 years. Personally i want something faster
only thing i'm worried about is if something aftermarket (like the b16 engine) goes out, that it would take a while to fix...
Old Dec 25, 2004 | 05:59 PM
86si's Avatar
b16 aftermarket? a b16 is just as reliable as the stock motor and just as easy to repair.
Old Dec 25, 2004 | 06:02 PM
Default Re: EF reliability (86si)
well its a jdm b16, isn't that different?
(sorry, Im VERY new to this)
Modified by Killerrobotjews at 7:21 PM 12/25/2004
Old Dec 25, 2004 | 06:09 PM
86si's Avatar
parts are everywhere for the B16 92-93 gsr B17, 94-97 del sol vtec and 99-00 civic Si all USDM models. No need to worry about getting parts or getting it repaired. If you like it buy it.
Old Dec 25, 2004 | 06:22 PM
Thats all I wanted to hear Thanks.
Old Dec 25, 2004 | 08:44 PM
j.c.'s Avatar
I would seriously do a compression test on the motor. It could have been thrashed hard as hearing your engine go into vtec land can be habit forming
Old Dec 25, 2004 | 09:54 PM
Default Re: EF reliability (j.c.)
how do i go about doing that?
92db2gs-r
Suspension & Brakes
Dec 5, 2010 12:00 AM
drg007
Jul 16, 2008 12:01 PM
efHondefender
Jan 31, 2006 05:58 AM
hXc-DC2
Dec 28, 2004 07:57 PM
Killerrobotjews
28
Dec 27, 2004 11:27 PM
