Tough choice guys... what set of mods to get next?
Old Dec 25, 2004 | 05:11 PM
JoeB18R's Avatar
Default Tough choice guys... what set of mods to get next?
Okay, I need to finish up with my new engine. I figure its going to take me 2 more "stages" before its complete. In all I still need:
-aftermarket intake manifold (AEBS)
-65+mm throttle body
-free flow cat
-cat-back exhaust (am using stock right now)
-2 layer head gasket (raise CR by .4)
-Cams
-Cam gears
Now I figure I will break buying that stuff up into 2 parts, or "stages" if you will. Since it ill end up costing me about the same for either "stage", I’m asking which I should do first? One would assume that the stock exhaust would seriously choke an engine that’s not only bigger then what it was designed for, but will be running aggressive cams. On the other hand, the cams will net me the most HP out of any of the other mods...
But I digress.
Now, I found a great deal for the cams I want (buddy club stage 3+), that includes shipping AND a set of BC cam gears. Since this is considered "head work" I would also have the 2 layer gasket installed, which is an additional 150 for parts/labor.
-However-
For around the same amount of money, I could get a very nice cat-back exhaust, free flow cat, intake manifold and throttle body.
So I put it up to you, SvA. What should I do? What makes more sense? None of this is written in stone, so if you can recommend a different set of parts to purchase in a different order, please let me know.
Thanks in advance,
-joe
Old Dec 25, 2004 | 08:32 PM
87sivtec's Avatar
I would get your second option first- the catback, throttle body and manifold.
My reasons are, the gains from the cams will be much higher after this.
Old Dec 25, 2004 | 09:35 PM
kaptr1d's Avatar
Default Re: Tough choice guys... what set of mods to get next? (JoeB18R)
get basic i/h/e before u do cams. the motor is gonna be chokin with stock parts and aftermarktet cams.
also a good header should be higher on ur list then a thorttlebody.
gl
Old Dec 25, 2004 | 10:04 PM
JoeB18R's Avatar
Default Re: Tough choice guys... what set of mods to get next? (kaptr1d)
i already have a JDM ITR header.
ludekid4323
Feb 2, 2009 11:08 AM
tomlinson619
Mar 31, 2006 06:27 PM
fastludeh22
May 6, 2004 08:59 PM
Crackerballer
Dec 30, 2003 01:04 AM
legendboy
Jun 18, 2002 08:00 AM
