What wastegate are you guys using?
Old Dec 25, 2004 | 12:25 PM
siblues's Avatar
Default What wastegate are you guys using?
I have been reading up on wastegates and what sizes are good for the hp you want to make. I am sure I have probably asked quite a few people on here but I figured I would get a better feel for what size I would realistically need by asking all of you guys with real world experience.I personally would need a gate that would work well with boost ranging from 10 to 19 psi and producing 350 to 500 hp?Any help is greatly appreciated
Old Dec 25, 2004 | 12:50 PM
GEN2TEG's Avatar
Many on here use the Tial wastegates. They are very reiable and hold boost levels very well. I have yet to hear one bad thing on Tial products.
I run a Tial and love it.
Old Dec 25, 2004 | 01:01 PM
siblues's Avatar
Default Re: (GEN2TEG)
Yeah I was planning on getting the tial but cant decide on what size ? What size are you using and whats your setup?
Old Dec 25, 2004 | 01:07 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (siblues)
im running a tial 38mm......going for 400whp on wed.
Old Dec 25, 2004 | 01:21 PM
siblues's Avatar
Default Re: (Hella_JDM)
Good thats the size I am thinking of getting and good luck with the 400 hp mark.
Old Dec 25, 2004 | 02:31 PM
SpoolnG2's Avatar
its actually really gonna depend on what size turbo your using and how much boost you plan to use. But yes, Tial is highly reccomended.
Old Dec 25, 2004 | 02:47 PM
siblues's Avatar
Default Re: (SpoolnG2)
Well right now I am using a t3/t04e but will be upgrading and I plan on running in between 10-18 or 19 psi?
Old Dec 25, 2004 | 02:50 PM
accordking's Avatar
Does anyone think a 35mm Tial will support over 20 lbs with this PT67
Old Dec 25, 2004 | 02:59 PM
Frozen E's Avatar
H-T White Ops
<--38mm Tial WG and 50mm BOV here.
Old Dec 25, 2004 | 03:17 PM
BoostedEG6's Avatar
Default Re: (accordking)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordking &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone think a 35mm Tial will support over 20 lbs with this PT67
hahahaha I hope you joking right? I mean it could work but you want something more along the lines of a 44mm or a 46mm but thats just me on what I would use
Old Dec 25, 2004 | 03:26 PM
adseguy's Avatar
Default Re: (BoostedEG6)
If you plan on using race gas make sure to get the special Tial one designed for it otherwise the valve could stick shut and BOOM. I forget the name of it though
Old Dec 25, 2004 | 03:38 PM
VI Boost's Avatar
Default Re: (IslandSi)
&lt;--- SSAutoCrap... I mean AutoChrome 38mm wastegate with 12psi spring. Seriously though, it works great, I have no complaints about it.
Old Dec 25, 2004 | 03:56 PM
siblues's Avatar
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">If you plan on using race gas make sure to get the special Tial one designed for it otherwise the valve could stick shut and BOOM. I forget the name of it though </TD></TR></TABLE>
I thought they only made the standard gates and their hp series and I thought the only difference between the two were the spring rates?But I am a noob so I am probably wrong
Old Dec 25, 2004 | 03:59 PM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">
I thought they only made the standard gates and their hp series and I thought the only difference between the two were the spring rates?But I am a noob so I am probably wrong</TD></TR></TABLE>
no your right..... there is no such thing as a wastegate for racegas.... someone just talking out there ***....... all wastegates operate the same and race gas exhuast is the same as gas exhaust except the smell hehe....
Old Dec 25, 2004 | 04:02 PM
siblues's Avatar
Well keep em coming guys what are you using and and how much hp? If you had a bad experience let me know so I can stay away from it ?
Old Dec 25, 2004 | 04:15 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">
no your right..... there is no such thing as a wastegate for racegas.... someone just talking out there ***....... all wastegates operate the same and race gas exhuast is the same as gas exhaust except the smell hehe.... </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1087090
So why is there an option to upgrade the valve then
PS&gt; I could be mean about it, but I'm not!
SpoolnG2's Avatar
actually your wrong. When you use race gas (leaded) the valve on the wastegates do have a tendency to start sticking. As for tial making a different valve, i thought they did but am not 100% sure.
Old Dec 25, 2004 | 04:26 PM
siblues's Avatar
Well you might be right but I went to tialsport.com and it didnt have anything listed as far as differences in how they make the wastegates .The hp and the standard are basically the same as far as construction.Someone correct me if I am wrong?
Old Dec 25, 2004 | 04:45 PM
jeiden's Avatar
this is what came with my tial WG when i ordered mine
Old Dec 25, 2004 | 05:00 PM
s2kdre's Avatar
Default Re: (jeiden)
35mm will hold 30 psi no prob.
Old Dec 25, 2004 | 05:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (jdmhonda)
tial 35mm here.
Old Dec 25, 2004 | 05:21 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeiden &raquo;</TD></TR><TR><TD CLASS="quote">
this is what came with my tial WG when i ordered mine</TD></TR></TABLE>
I had one of those too. Got 0wning on your part.
Old Dec 25, 2004 | 05:25 PM
AVATAR's Avatar
they do have unleaded race gas guys.
Old Dec 25, 2004 | 05:38 PM
poop II's Avatar
hahahaha I hope you joking right? I mean it could work but you want something more along the lines of a 44mm or a 46mm but thats just me on what I would use </TD></TR></TABLE>
Actually, the bigger the turbo, the less the necessity for a big wastegate on the same setup. A small turbo on high boost has the greatest potential to spike, hence the necessity for a good wastegate. Of course wg selection should also be dependant upon exhaust volume too, so it's kind of a hard thing to determine. Im no honda expert, but i'd say a Tial 35 would work and a 38 would definatly be adequate for both Siblues and Accordking. Look at all the cars that have gotten away with 31mm deltagates all these years.
Old Dec 25, 2004 | 05:41 PM
JDMCRX's Avatar
Default Re: (poop II)
Tial 35mm man nothing but the best.
