Mig Welder Question
I got a 90amp mig welder and i wanted to know if that would be enough for creating intercooler aluminum piping and welding them together and putting a flange on and such?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiceg500 »</TD></TR><TR><TD CLASS="quote">What i have is a flux wire welder, that is 90 amp. People would this weld aluminum?</TD></TR></TABLE>
Nope, your welder will work with sheet metal and thin steel. If you would like to weld stainless or aluminum you need a MIG welder with gas. If your on a budget, check out HarborFreight.com they have a gas/no gas Chicago Electric MIG welder for $175 (marked down from $350).
-Mike
-Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blurboEK »</TD></TR><TR><TD CLASS="quote">
-Mike</TD></TR></TABLE>
But understand what your buying when its from Harbor Freight..
You need pure argon as a sheilding gas to weld aluminum.. No flux core for that type of stuff.. And add about $100 to the sale price for an aluminum upgrade kit.. IE liner and wire, tips etc..
could you answer this for me please, could i use the flux wire welder to weld mild steel or aluminized steel? It is a 90amp welder
i'm pretty sure if you have the gas, and you buy the aluminum wire you could do it. if you want something small done, consider going to a local high school that has a welding shop and ask the teacher if he has any advanced students who could take on this project for you. I'm from washington and i know alot of times when someone who would come in and me or a few other students would end up having to do a project for someone(be prepared to pay them a few bucks though) Tig welding is a much better process when it comes to welding aluminum. Also if you have no experience with welding aluminum with a wire machine it's alot different than welding steel. burns way different and very easy to burn holes.
texm3x
Welding / Fabrication
11
Jun 4, 2011 02:01 AM
precisionsc54
11
Jan 26, 2010 08:06 AM
LordAphotic
Dec 25, 2007 01:25 AM
