STRIPPED HEADBOLT! What to do... Help!
Old Dec 25, 2004 | 01:26 AM
thevanitygroup's Avatar
Modified by thevanitygroup at 7:45 PM 3/29/2005
Old Dec 25, 2004 | 01:40 AM
StorminMatt's Avatar
Default Re: STRIPPED HEADBOLT! What to do... Help! (thevanitygroup)
Any time you have a problem such as this one, it is best to pull the head and remedy the situation. This is not a good situation. And leaving it is not going to make anything better. You will have to drill out the old threads and use a Heli-Coil or similar thread insert to fix it. Also, you might want to go with studs while you are at it. Studs have the advantage of not being turned under a load (and thus galling the threads).
Old Dec 25, 2004 | 01:54 AM
DEVIOUS_EG*'s Avatar
Default Re: STRIPPED HEADBOLT! What to do... Help! (StorminMatt)
i wouldn't use the Helicoil stuff.. heard many horror stories about them coming apart etc.. go with these ---> http://www.timesert.com/
Old Dec 25, 2004 | 02:08 AM
Default Re: STRIPPED HEADBOLT! What to do... Help! (DEVIOUS_EF*)
We'll... I was planning a complete head to toe rebuild in January. Should I be able to daily drive it like this for the next month or so without wapring my head or further damge. I mean it is ONE bolt and my head gasket has 20k miles on it without leakage so far.
Old Dec 25, 2004 | 02:14 AM
Surubasi00's Avatar
i personally wouldnt risk it, pull the head and see what the problem is, should take you a day to do the whole thing, a day is worth not warping a head, plus you may have to pull it anyways in case your headgasket DOES start leaking preventative maintenance is a good thing
Dave
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
Raptastik87
Jan 21, 2008 05:38 PM
Day-DayC
May 18, 2006 08:51 PM
BB6-213
Apr 22, 2006 11:35 AM
MRN1120
Jun 22, 2004 09:58 PM
