Fuel Pressure Gauge on Fuel Rail
Old Dec 24, 2004 | 04:45 PM
AlxSiR7's Avatar
Default Fuel Pressure Gauge on Fuel Rail
Does anyone know where I can get a little mechanical fuel pressure gauge to install on my STR fuel rail??
Old Dec 24, 2004 | 06:44 PM
v4lu3s's Avatar
RTFM
summit racing
Old Dec 24, 2004 | 07:16 PM
AlxSiR7's Avatar
Default Re: (v4lu3s)
do you know the thread size i need for the str rail?? i have the newer type with the gauge hole already there...
Old Dec 24, 2004 | 09:15 PM
IN VTEC's Avatar
Default Re: (AlxSiR7)
1/8" NPT. I haven't seen a fuel pressure gauge yet that wasn't 1/8" NPT.
Old Dec 24, 2004 | 10:05 PM
PrettyLude's Avatar
the one at summit racing is cheap and works good
Old Dec 24, 2004 | 10:16 PM
turbohonda's Avatar
Default Re: (PrettyLude)
Mounting a mechanical fuel pressure gauge on the fuel rail is a bad idea. The vibration from the motor will eventually rattle the guage apart and cause a fuel leak. I would definetly mount it somewhere else and use a remote line (-4an) to connect it to the rail. Summit sells an Auto Meter mech. guage and optional -4 line in different lengths for this.
Old Dec 25, 2004 | 05:51 AM
AlxSiR7's Avatar
Default Re: (turbohonda)
why would str put a mounting hole on their newer rails then?? it seems pretty sturdy too me.. its not some custom job
Old Dec 25, 2004 | 06:35 AM
xbn83's Avatar
It is not true. I have B&M fuel pressure mounts right on top of AEM fuel rail for over a year now. No fuel leak, no problem.
Old Dec 25, 2004 | 07:04 AM
AlxSiR7's Avatar
Default Re: (xbn83)
yeah.. thats what i though..
Old Dec 25, 2004 | 09:27 AM
Artful Dodger's Avatar
it would be better to mount it somewhere else, but it will probably be fine on the rail. it may be a little harder to read because of the vibrations too.
Old Dec 25, 2004 | 11:03 AM
Big Teggie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">the one at summit racing is cheap and works good</TD></TR></TABLE>
I agree
Old Dec 25, 2004 | 01:19 PM
turbohonda's Avatar
Default Re: (Big Teggie)
I am just explaining this from experience. I went through two VDO guages and one time it left me stranded with a fuel leak. They put the 1/8th NPT on the fuel rail for many reasons, not just to mount the guage. Go ahead and try it, if it works good for years then more power to you. If it rattles apart and leaks, then I told you so.
Projekt_2nr
Mar 7, 2007 08:30 PM
Reddog
Sep 30, 2002 12:42 AM
Accord EX F22
Aug 9, 2001 05:07 PM
