90-'91 CRX DX vs Si TPS
Old Jan 6, 2002 | 05:38 AM
91CRX-DX's Avatar
Default 90-'91 CRX DX vs Si TPS
I've just about got all the misc. pieces and parts lined up for a MPFI swap on my 1991 CRX-DX. I purchased a "complete" intake assy to find that the throttle position sensor (TPS) was trashed... big surprise. I scoured the local salvage yards only to find that every D15/16 motor that still had a throttle body attached had a battered TPS. Long story over, here's my question....
As the TPS on my DX's D15 engine is in fine shape, is this compatible to just swap over to the '90 Si throttle body?
If not, anyone out there have the correct TPS available?
Thanks in advance.
-pws-
Old Jan 6, 2002 | 07:36 AM
Blown90hatcH's Avatar
Default Re: 90-'91 CRX DX vs Si TPS (91CRX-DX)
Yeah....they are the same. Just swap them over.
Old Jan 6, 2002 | 08:38 AM
91CRX-DX's Avatar
Default Re: 90-'91 CRX DX vs Si TPS (Blown90hatcH)
Thanks for the confirmation! One less thing to worry about....
-pws-
Old Jan 6, 2002 | 03:47 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Not the same!!!
The DX TP sensor (EF) is the only one that will not work.
It spins in the opposite direction.
It will bolt right up, but will not work.
One more thing, it is also wired differently, if you are using a DX harness on
any other TP sensor, you have to switch the two outer wires.
Old Jan 6, 2002 | 11:08 PM
Default Re: 90-'91 CRX DX vs Si TPS (Spaceballs the lunch box)
Thats wierd....Never had any problems with swapping them.. I dunno
Old Jan 7, 2002 | 10:47 AM
SiR Kid's Avatar
New User
DX swings the opposite direction of the Si and HF.
They sit completely different. If the TPS is made to bolt onto the throttle body, it won't rotate because it's at the extent of it's rotation before the throttle is moved... I tried that too
Good news is that ANY TPS off of a 4 injector honda will work. As long as it's not a downward pointed TB, you're good to go.
I think my B16a has a TPS off of a 93ish CX engine right now.
Old Jan 8, 2002 | 03:40 PM
iwhichisme's Avatar
i was wandering, been to the junkyards trying to get another TPS, and was wandering how in the hell you take one off, they all seem to be rivitted on. Also from what car would work best for a 1st gen b16
dtgodmage
Jun 8, 2011 05:57 AM
E-AT_me
Feb 12, 2008 05:13 AM
streetdreams420
Aug 13, 2003 07:55 AM
92'gsrhatch
May 24, 2003 07:53 PM
AGPSuperstar
76
Apr 12, 2003 08:58 AM
