how much juice can I use
Old Dec 24, 2004 | 02:15 PM
JDM JEFFREY's Avatar
Default how much juice can I use on high comp motor?
I just want to know if this will be safe with a 50 shot or how much nos I can run??
96 ls block .25 over
11.5 comp Je pistons(srp)
eagle rods w/arp rod bolts
crank rods and pistons have been balanced
97 gsr head (stock)
skunk2 intake manifold
rpm 68 mm t/b
skunk 1 cams
omni valve train
profab header
r/c 310cc injectors
hondata s200
Old Dec 24, 2004 | 02:21 PM
HamiltonRex's Avatar
Default Re: how much juice can I use on high comp motor? (JDM JUICE)
if you retard timing according to the manufactures recommendations, and run colder plugs etc.... You should be fine
Just dont run a program that advances timing too much, run 16deg ignition timing.
a 50 shot should be fine, im running a 75 wet shot on a stock gsr with no problems.
95% of nitrous problems is due to installation or inproper use.
-Eric
Old Dec 24, 2004 | 05:32 PM
Tuesday Club's Avatar
Default Re: how much juice can I use on high comp motor? (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">
-Eric</TD></TR></TABLE>
Just watch your ignition timing
Old Dec 24, 2004 | 08:42 PM
Default Re: how much juice can I use on high comp motor? (mercuryfrost)
what should my timing be set at???
thehatchninja
Dec 25, 2006 08:15 AM
JDM H22
Jun 17, 2005 02:54 PM
DocSean
Jan 17, 2005 10:05 AM
ninja8oi
Nov 21, 2003 12:53 AM
GSRontheBottle
Dec 27, 2002 12:19 PM
