how do I inspect a crank? pics of the bearings inside
Too much eccentricity on the rod big-end?
What does the bearing half on the cap-side look like? Same mirrored wear pattern?
Is that a main bearing in that rod, or does that rod have an oiling hole?
A machine shop can inspect it and micropolish the journals for like $40 bucks. If your reusing it with fresh bearings i would def get it micropolished. Its cheap and it will be much nicer, plus they inspect it !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">Is that a main bearing in that rod, or does that rod have an oiling hole?</TD></TR></TABLE>
i was thinking the same thing
To check for cracks on the crank: Magnaflux testing is where you spray a die on the crank wipe it off and the look at it under a black light. If you see a glowing line then thats were a crack is. Have the journals polished too.
kornerk12
Oct 8, 2007 05:08 AM
eg4life1202
11
Jan 14, 2007 09:17 AM
