need quick ecu help.
my check engien came on. ecu flashes 1 time when i first urn the key and then it goes 9 times.
im away from home and will be til after xmas. anyone with a manual please help me out.
thanks!!!
thanks!!!
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2 *not all cars*
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
Modified by GreenMachineRex at 2:08 PM 12/24/2004
Try unplugging your battery for about 1 min(or hazard fuse). And if that doesnt work unplug your ECU and see if that makes the CEL go away. If those 2 doesnt solve it. Its your distributor.
i had that also. I unplugged my battery and nows its gone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex »</TD></TR><TR><TD CLASS="quote"> ecu flashes 1 time when i first urn the key
thats a self test flash signaling the ecu is in good working order. that used to freak me out when i first did my swap until someone told me, thought you might like to know as well.
solid red light is the old 'time to buy a new ecu' sign.
91ef8sir
20
Jan 29, 2013 11:24 AM
