1999 accord problems
Old Dec 24, 2004 | 05:40 AM
microjubei's Avatar
Default 1999 accord problems
hey guys new to the site(officially), but have been a lurker for some time. let me say your advice is top-notch. So hopefully someone can help me. I have a 99 accord 4cyl. 2.3L-w/ 136,000 miles. As of recent the car cuts off on me, usually at red lights, but also when I'm driving on the highway. by "cut-off" i mean the RPM's (at red lights) will got from around 900(where it usually is at idle) to 700 to 400 to zero. between the 700 and 400 the car will shake as if it has little to no gas. when the car "cuts-off" I will let it sit for literally 30 seconds, crank it up and it starts fine and gets me the rest of the way to my destination with no problems. It does this once every trip. My "check engine" light is on and has been for 5 months, when I took it to Auto zone(5 months ago) they said it was a bad o2 sensor. (i know 5 months is too long to go on with a check engine light on but I am a broke college student. I took it to Honda and they said it wasnot an O2 sensor, but a malfunctioning computer and bad cat converter-est cost-$1200. I ask some friends who have a hair more automotive knowledge the myself and they said it was a bad or clogged fuel filter.......can anyone help or is this the end of my "reliable" college car......any info will be great...Thanx and Happy holidays
Old Dec 24, 2004 | 05:57 AM
lakerschamp2000's Avatar
Default Re: 1999 accord problems (microjubei)
main relay.
Old Dec 24, 2004 | 06:06 AM
microjubei's Avatar
Default Re: 1999 accord problems (lakerschamp2000)
main relay----how much $ to fix it say from the dealer or firestone??----ohh yeah thanx for the help ps... is it something a novice like myself can fix???
Old Dec 27, 2004 | 04:51 PM
spooned out's Avatar
hey man chance are u mite have a bad ignition switch...ussually when those get hot ..they cut off..
also ur 02 plays a roll in ur car dieng...air/ fuel not reading properly can cause car to cut off..
but i go with the ignition switch...the ''elctrical part of igniton switch...
see if ur car falls in the recall catagory at the honda dealership...im pretty sure i think those years has an ignition switch recall...the dealership can look it up 4 u...they will kno if ur car has the recall...or not..
Old Dec 27, 2004 | 04:54 PM
hey..i would do the o2 sensor tho cause...if ur car is a 5 speed..its a definite o2 sensor...i experienced it...
Old Dec 27, 2004 | 04:55 PM
when ignition gets hot it cutts the car off...give it time to cool it will crank ryte up...im pretty sure it s the 02 sensor or igntion...ur choice to do 1st
Old Dec 27, 2004 | 07:46 PM
Heat's Avatar
Default Re: 1999 accord problems (spooned out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out &raquo;</TD></TR><TR><TD CLASS="quote">when ignition gets hot it cutts the car off...give it time to cool it will crank ryte up...im pretty sure it s the 02 sensor or igntion...ur choice to do 1st</TD></TR></TABLE>I have no idea which is right, but from experience, fix the cheapest one first.
Old Jan 29, 2005 | 03:24 PM
keykey's Avatar
Default Re: 1998 accord problems
I have a 1998 Accord v6 and at about 25mph it starts as though it is going to shut off and it jerks into turbo what causes this. Also the check engine light was on for the past 4 days does this have anything to do with that. Can someone help?
Old Jan 29, 2005 | 03:27 PM
keykey's Avatar
Old Jan 30, 2005 | 06:57 AM
SuperSlow's Avatar
Default Re: 1999 accord problems (keykey)
Pull the codes and find out. Turbo? Wow.
Old Jan 30, 2005 | 07:07 AM
accordselux's Avatar
Me Gusta History
Default Re: 1999 accord problems (SuperSlow)
If you want to check your ignition, go to the dealer. Some 6th gens have faulty ignitions, and you might be able to say 'the key came out while the car was in drive' and theyll replace it for free...
Old Jan 30, 2005 | 10:42 AM
Bishop Don Shizzle's Avatar
Oh yeah I forgot I can edit my own title! Yay!
Default Re: 1999 accord problems (accordselux)
I am having this problem as well only the shaking and cutting out occurs on cold starts. The engine doesn't totally cut out but it becomes a rough idle and the RPM drop to about 300. If I warm up the car it's okay. It's just weird because I have a '99 and live in CA. It's not exactly freezing cold around here.
Old Jan 30, 2005 | 11:57 AM
shadow_ridge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keykey &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1998 Accord v6 and at about 25mph it starts as though it is going to shut off and it jerks into turbo what causes this. Also the check engine light was on for the past 4 days does this have anything to do with that. Can someone help?</TD></TR></TABLE>
sounds like the tranny is on the way out, most likly it slipt a gear and it caused it to pull you ahead so hard..."the turbo felling" i know how it fells
Old Jan 30, 2005 | 01:49 PM
philadd's Avatar
Default Re: 1999 accord problems (shadow_ridge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow_ridge &raquo;</TD></TR><TR><TD CLASS="quote">
sounds like the tranny is on the way out, most likly it slipt a gear and it caused it to pull you ahead so hard..."the turbo felling" i know how it fells</TD></TR></TABLE>
I disagree. He says it acts like it's going to shut off, suggesting stumbling or something of the sort. A slipping tranny would cause the opposite... When the tranny attempts to shift gears, the rpms shoot up before finally slamming into the next gear, thus jerking the car forward.
I say, check the CEL code, as it might very well have something to do with the problem.
As for the original poster, I would recheck the codes before attempting any repairs... just to make sure.
Old Jan 30, 2005 | 11:39 PM
JmbElite16's Avatar
I wish I checked up on that recall thing. I have a 98' (6th gen) and it was having problems turning on unless I turned the key and held it just right. Also if I touched it, it would shut the car off while I was driving on the highway or anywhere. I handled it well since I drive a manual and can just hold the clutch down and coast until the car ignites up again. The time it would get scary was when it did it during a turn. Without power steering it was impossible to turn and the steering wheel would lock up. Sigh. Cost me about $1000 to have the ignition switch and the o2 sensor done. Greatttt...
Old Feb 1, 2005 | 03:43 PM
longbeachpurplecivic's Avatar
Default Re: (JmbElite16)
dang i feel sorry for you accord owners seems like accords are hondas fast way of makin money with all these problems
Old Feb 1, 2005 | 03:59 PM
businessmanph's Avatar
Default Re: (longbeachpurplecivic)
do honda use non honda parts for example the 97 accord v6 used a mitsu alternator
Old Feb 2, 2005 | 05:44 PM
keykey's Avatar
We got the code it read P0740 tcc circuit malfunction&gt; Everyone tells us that we're better off replacing the transmission. Does anyone have any suggestions or where we could get one at a good cost.
Old Feb 2, 2005 | 10:29 PM
m0nkey's Avatar
for the poster:
I had a problem with my ignition switch; the engine will completely shut off (no hesitation, no slow drop in rpm). For Accords year '98-99, there is an ignition switch recall. Just can any Honda dealer and give them your VIN number and they'll get it done for you. There is also an idle screw recall.
Most of the 6th gen Accords get the cat. converter check engine code. Most of the time, resetting it will get it to go away, but it comes back intermittenly. Under the hood, open the fuse box and pull the "back up" fuse ( it's a 30 or 40A one) out and then put it back after 30 seconds. It should reset your check engine light, also your clock.
Ohreally209
Oct 5, 2018 06:20 AM
Greg Bark
20
Jun 13, 2016 03:51 AM
sherryc307
May 30, 2015 01:13 PM
mehdi
Nov 10, 2004 08:26 AM
Ya@inlinePRO
Dec 23, 2003 11:20 AM
