got a newbie question
yeah dont really know too much here.. but which would be better to go with? h22 or h23 for a turbo setup? i was thinkin h22 because i wont have the turbo for a while and might as well have vtec handy but i think i recall people saying 23s are better for turbo.. what should i do? i mean i love vtec.. does it REALLY make a biog difference..t hanks
wellto give you a general idea of the main differences:
H22A (VTEC) with turbo = harder to tune but you'll make more power
H23 (NON-VTEC) with turbo = easier to tune but you'll make less power
custom set ground being? i mean obviously im not leaving stock parts on the motor so if you saying all i need are better cams n gears then im set.. thanks.
oh by the wya.. when the other guy said more tuning vs less tuning.. how much of a difference? seing that the 22 would give me more horse makes me pretty much decide on that but i just wanna know
If you want to add a high psi turbo, go with a larger engine - 2.3L.
I think maybe the reason the H23 doesnt make as much power is cause it doesn't "inhale" as well as the H22. the H22 VTEC can inhale a lot more air than the H23 Non-VTEC, obviously because of the different cam profiles. Also the H23 has a lower redline (6500)
I've seen HP numbers for the H23 vs the H22 VTEC with the same PSI level, and the H22 always had the higher HP #'s
well what you mean by high psi? im thinkin 10 daily but maybe over the weekend when i wanna go run my car maybe 15/16? is that high
some people say different things about how much boost the stock H22 can take, but for me I say that 8-9 PSI is the limit for the stock with "good tuning". but of course thats me.
EDIT if you are gonna be boosting 10-15 PSI I would worry about replacing the stock cams until AFTER you've built the bottom end. some things you'll have to do are:
-Resleeve the block
-Turbo pistons & rings
-Rods
-head bolts
am I leaving anything out?
[Modified by BlueShadow, 10:36 AM 1/7/2002]
