my not so diy arc box
Old Dec 23, 2004 | 11:27 PM
morepoop4u's Avatar
Default my not so diy arc box
cardboard mock up.
16 gauge sheet metal. notice my beautiful welds
thermal coating (bbq paint)
i've noticed more mid to top end powa on my jrsc gsr
my previous setup was a modded intake arm to stock are box and comptech filter. i also had a dryer hose routed to the box.
p.s. anybody have welding tips to get a good bead. i have a lincoln weld pak 100. what type of pattern should i do to lay a nice bead, zig zag, semi circles?
Old Dec 24, 2004 | 05:37 AM
Canuk_SiR's Avatar
Default Re: my not so diy arc box (morepoop4u)
nice build
Old Dec 24, 2004 | 07:27 AM
TIGboy's Avatar
Default Re: my not so diy arc box (Canuk_SiR)
yes, nice
Old Dec 24, 2004 | 11:32 AM
sporkcrx's Avatar
Default Re: my not so diy arc box (Dsmboost05)
Turned out very nice!
Old Dec 24, 2004 | 11:55 AM
rgbpmp's Avatar
Default Re: my not so diy arc box (sporkcrx)
Just get a grinder and grind them down. If your welder is a gassless welder you will have slag. Try to grind if you make a new one, then paint.
But never-the-less it looks good.
Old Dec 24, 2004 | 10:00 PM
DFW's Avatar
DFW
Default Re: my not so diy arc box (rgbpmp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canuk_SiR &raquo;</TD></TR><TR><TD CLASS="quote">nice build
Old Dec 24, 2004 | 11:59 PM
MaskedAP1's Avatar
Default Re: my not so diy arc box (DFW)
nice
Old Dec 25, 2004 | 02:24 PM
Tony the Tiger's Avatar
Foam filter with JRSC?
You should read Jackson Racing's warning against using foam filters...
Old Dec 25, 2004 | 07:53 PM
morepoop4u's Avatar
Default Re: my not so diy arc box (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">Foam filter with JRSC?
You should read Jackson Racing's warning against using foam filters...</TD></TR></TABLE>
you got a link?
i've been running it for 3 years now without any problems
JR sells foam filters too http://jacksonracing.com/Shop/...38960
Old Dec 26, 2004 | 11:16 AM
adictionbass's Avatar
i never really got the point of these, but looks good
Old Dec 27, 2004 | 03:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by morepoop4u &raquo;</TD></TR><TR><TD CLASS="quote">
you got a link?
JR sells foam filters too http://jacksonracing.com/Shop/...38960</TD></TR></TABLE>
It states that in the installation PDF instructions in the recommended upgrades section (last two pages). It mentions not to use any aftermarket foam filters and try to stick with the stock one or an oiled K&N. On the new JR website though, it seems like have removed the installation instructions page so I can no longer access the PDF files online.
Perhaps they are referring to non-oiled foam filters. If the filter you are using is preoiled or uses oil, then it should be okay.
Old Dec 27, 2004 | 03:34 PM
Steve91's Avatar
How's that thing sound? I bet it changed the intake note quite a bit. Nice Job!!
Old Dec 27, 2004 | 05:19 PM
xci_ed6's Avatar
Default Re: my not so diy arc box (Steve91)
here's an idea....
weld the inside then use seam sealer on the outside, then you won't be showing off the shitty welds you get with flux core. Not ragging on you, all I've got at home is a flux core mini-mig too
Old Dec 27, 2004 | 05:29 PM
el arbi's Avatar
Default Re: my not so diy arc box (krustindumm)
Hahaha, AWESOME job man. Looks really good
Old Dec 27, 2004 | 10:01 PM
Boltz's Avatar
Default Re: my not so diy arc box (99SiRacer)
looks good, lets see it in the car
Old Dec 28, 2004 | 08:09 AM
BlkslowCRX's Avatar
Nice set up I like the air horn
Heres some Picture of my setup Made out of .0625 alum sheet and 1/4"x1/4" alum angle. there is a AEM filter in side the box , The box get air fed around the head light and from a scoop in the bumper. Ran it at gingerman and the box stayed ice cold the whole time
I know the bays dirty its a midwest daily driven car what ya expect
Old Dec 28, 2004 | 09:25 AM
david@didrace.com's Avatar
Just a suggestion to make it look better with the tools you have. Bend the sheet metal to make different facets instead of welding each facet to the rest of them. You could probably have gotten away with making 3 welds this way.
Old Jan 1, 2005 | 12:20 AM
morepoop4u's Avatar
Default Re: my not so diy arc box (backpurge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">Just a suggestion to make it look better with the tools you have. Bend the sheet metal to make different facets instead of welding each facet to the rest of them. You could probably have gotten away with making 3 welds this way.</TD></TR></TABLE>
where's the fun in that i need to practice my welding on something you hardly notice the welds after i painted it.
Old Jan 1, 2005 | 10:41 AM
projecthybrid04's Avatar
thats some good ****
Old Jan 1, 2005 | 12:14 PM
24valvage's Avatar
if you grinded those welds, it would've looked awesome. But still a great DIY
Old Jan 2, 2005 | 05:08 AM
mrDFWmechanic's Avatar
nice diy
Old Jan 2, 2005 | 09:33 PM
menkio's Avatar
Default Re: (iROCKtheSOHC)
second one was clean, first one.. damm yo DA GRINDA
Old Jan 3, 2005 | 07:08 PM
richeybrooks's Avatar
Default Re: (menkio)
its not going to make your car any faster. welds look bad. it make your engine bay look horriable
Old Jan 4, 2005 | 08:30 AM
SkRiBLaH's Avatar
Default Re: (richeybrooks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richeybrooks &raquo;</TD></TR><TR><TD CLASS="quote">its not going to make your car any faster. welds look bad. it make your engine bay look horriable</TD></TR></TABLE>
having a bad day?
Old Jan 24, 2005 | 12:27 PM
scoop's Avatar
Good info
