Tire Rub issue
Old Dec 23, 2004 | 10:36 PM
jeffk182's Avatar
Default Tire Rub issue
I have a 2000 Si, lowered 2'' with progress springs and Tokico illumina shocks. Im using the stock alloy rims(15'') with Dunlop SP Sport 195/55/15 and im getting mad tire rub during hard cornering. What can I do to get rid of this problem? Thanks.
Old Dec 23, 2004 | 11:09 PM
eJone powereD's Avatar
Default Re: Tire Rub issue (jeffk182)
raise the car tad bit more with different springs that don't lower it that much...or go with thinner tires...say 50 series or 45 series isntead of 55...but if you dont want to do either, then there's no other way
Old Dec 23, 2004 | 11:26 PM
spankey167's Avatar
You can also roll your fenders
Old Dec 23, 2004 | 11:34 PM
=GAME='s Avatar
Default Re: Tire Rub issue (spankey167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankey167 &raquo;</TD></TR><TR><TD CLASS="quote">You can also roll your fenders </TD></TR></TABLE>
Old Dec 23, 2004 | 11:38 PM
jeffk182's Avatar
So getting like a 50 series tire would help? Thats actually pretty good then, cuz im gonna be needing new tires pretty soon
Old Dec 23, 2004 | 11:40 PM
jeffk182's Avatar
When you roll your fenders, does it bend the entire fender, or just the thin tab on the fender inside of the wheel well?
Old Dec 23, 2004 | 11:43 PM
=GAME='s Avatar
Default Re: (jeffk182)
thin tab.
Old Dec 23, 2004 | 11:44 PM
white-ek's Avatar
Default Re: (=GAME=)
raise car or smaller tire
Old Dec 24, 2004 | 12:03 AM
skip.two's Avatar
try the 195/50. if that doesn't work, then you're going to need to raise the car up some.
Old Dec 24, 2004 | 04:48 AM
ironlung78's Avatar
where is it rubbing the front or back??? sounds like you have some serious body roll.. you shouldn't and personally i wouldn't roll my fenders for factory size tires..
my 00si is on the ground with factory's and doesn't rub at all!!!
you may want to invest in Coilovers or update the rear sway bar (its only 13mm)
Old Dec 24, 2004 | 09:19 PM
jeffk182's Avatar
Hrmm...it seems like both the front AND rear rub. I guess I have some body roll now... I was thinking of saving and getting HKS Hipermax II coilovers in the future.. I guess i'll try 50 series tires, and if that doesn't help, i'll find a way to roll my fenders. Thanks for the help guys!
Old Dec 24, 2004 | 11:06 PM
Yumm Tum Yummm's Avatar
Roll the fender tabs. I had the same issue before
Old Dec 25, 2004 | 01:00 AM
jeffk182's Avatar
Default Re: Tire Rub issue (EJ_FaNaTiK_22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ_FaNaTiK_22 &raquo;</TD></TR><TR><TD CLASS="quote">Roll the fender tabs. I had the same issue before </TD></TR></TABLE>
Haha aiite...i'll see about that. I hear that your paint might crack? How would I come about preventing this?
vietxdragon
Apr 2, 2008 08:50 PM
95teg_ls
Oct 10, 2007 12:27 PM
bigkshep
Apr 2, 2005 09:24 AM
gocivicgo
Aug 28, 2003 01:21 PM
gocivicgo
10
Aug 28, 2003 09:38 AM
