Reinstalled dash car won't crank..
Old Dec 23, 2004 | 06:21 PM
97itr86's Avatar
Default Reinstalled dash car won't crank..
Ok here is the story I removed my dash to put heat back in my car. I got frustrated and
decided to put the dash back in. I put the dash back in and now it will not crank. The starter will turn the motor but the car will not crank and idle. It is getting gas and I checked for spark. I have found one place on the steering column where it looks like a
plug should be. If you are looking at the iginition switch there is a top plug that is plugged in and up under it there is a plug not plugged in. Also I have a push button start. By the way car is a 92 Civic hatch.
Old Dec 23, 2004 | 07:02 PM
-Justin-'s Avatar
Default Re: Reinstalled dash car won't crank.. (97itr86)
if ur talkin about the plugs underneath the steering rack they all have to be plugged in, are you saying that u do not know where one of the ends of the plug are? sounds like u might have to pull the dash back out and get ur wiring straight, might have crammed some of it in there.
Old Dec 24, 2004 | 07:18 AM
97itr86's Avatar
Default Re: Reinstalled dash car won't crank.. (-Justin-)
Yeah that is my task for tommorow.
Old Dec 25, 2004 | 12:57 PM
97itr86's Avatar
I checked out the dash and saw nothing unplugged possible that my battery is ******* dead. When I try to jump it off it seems to die fairly quick. I have had some problems as of late cranking it in the cold.
seanbeck76
Dec 3, 2022 12:45 PM
94civic18
Paint and Body
Oct 3, 2007 07:16 PM
ek-NONE
Apr 23, 2006 11:58 AM
97itr86
Dec 29, 2004 03:58 PM
92B20GSR
Oct 16, 2003 06:10 PM
