LS swap questions
Old Dec 23, 2004 | 04:27 PM
Superdragr45's Avatar
Default LS swap questions
i have some simple questions about swapping the LS motor into a 99 EX............
can i reuse the engine harness without cutting or rewiring??
can i re-use the lower tranny bracket??? what brackets need to be replaced other than the drivers side bracket???
do i need to buy intermediate shafts along with the driveshafts from a B series????
Old Dec 23, 2004 | 04:42 PM
blackeg's Avatar
Default Re: LS swap questions (Superdragr45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 &raquo;</TD></TR><TR><TD CLASS="quote">can i reuse the engine harness without cutting or rewiring??
yes and no. you will have to extend some sensors, but this is not nearly as bad as entirely re-wiring. its no big deal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 &raquo;</TD></TR><TR><TD CLASS="quote">can i re-use the lower tranny bracket??? what brackets need to be replaced other than the drivers side bracket???
you will need the rear bracket that goes from the trans to the top of the subframe from a 99-00 si. you will also need the drivers side bracket from a 99-00 si. you can use the part of the stock civic mount that has the rubber on it, but the part you absolutely need from the si bolts to the block itself behind the timing belt cover. top tranny mount is all from your ex. if you want the front tranny, youll need one from the teg.
do i need to buy intermediate shafts along with the driveshafts from a B series????</TD></TR></TABLE>
yes. axles and intermediate shaft from any 94+teg or 99-00 si will work. you will also need the shift linkage from either of the 2 aformentioned cars.
endo617
Nov 26, 2007 07:03 AM
Dxs
11
Jul 25, 2007 10:22 PM
mjfx
Jul 9, 2007 06:54 AM
tdo
13
Aug 28, 2006 06:50 PM
R.and.Y
Jun 28, 2006 11:49 PM
