**HELP** tail light prob!! EG tech pro's plz help!
Old Dec 23, 2004 | 03:30 PM
jackarse's Avatar
I'm a Jackass
Default **HELP** tail light prob!! EG tech pro's plz help!
not sure what it's called but i think it's the "back up" light's of the tail lights on my eg that aren't working.. i got new bulbs for them but still they don't work.. not only the back lights, but also the reverse lights and the license plate lights are out.. and the bulbs seem fine on those.. i'm guessing it's the fuse? but the fuse seems fine also so i don't really know what the heck it is.. somebodyyyy helppppppppp...
here is a pic:
Old Dec 23, 2004 | 03:31 PM
len's Avatar
len
Default Re: **HELP** tail light prob!! EG tech pro's plz help! (EGcellent)
What fuse are you checking?
Old Dec 23, 2004 | 03:32 PM
jackarse's Avatar
I'm a Jackass
Default Re: **HELP** tail light prob!! EG tech pro's plz help! (len)
the "back up" light fuse..
Old Dec 23, 2004 | 03:48 PM
jackarse's Avatar
I'm a Jackass
bump for some help...
Old Dec 23, 2004 | 03:49 PM
jackarse's Avatar
I'm a Jackass
hell.. ppppp...
Old Dec 23, 2004 | 03:51 PM
Tyree's Avatar
check the wiring and also check the back up light switch on the tranny
Old Dec 23, 2004 | 05:02 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
check all your fuses again.. to me, it looks like none of your running lights are working, but the brakes lights come on.
check ALL the fuses. with a test light, and key on, engine off. every fuse under the dash should be working, or else it doenst' need to be there.
Old Dec 23, 2004 | 05:21 PM
spunky424's Avatar
Default Re: **HELP** tail light prob!! EG tech pro's plz help! (Built B16A)
any chance was the car automatic then converted to manual? if so you have to wire the reverse lights yourself...
Old Dec 23, 2004 | 08:32 PM
pinoyrukus's Avatar
Default Re: **HELP** tail light prob!! EG tech pro's plz help! (spunky424)
i don't think he converted it, All si's came in 5spd .
i think i know what might be wrong i'll PM you ^_^
Old Dec 23, 2004 | 08:34 PM
jackarse's Avatar
I'm a Jackass
thanks for the comments.. i guess it must be the fuses then.. i'll triple check it again tomorrow.. but last time i checked, the fuses were fine.. is there anything else it could be???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spunky424 &raquo;</TD></TR><TR><TD CLASS="quote">any chance was the car automatic then converted to manual?</TD></TR></TABLE>
^^^nope..
Old Dec 23, 2004 | 09:26 PM
jackarse's Avatar
I'm a Jackass
bumpity bump..
Old Dec 23, 2004 | 09:27 PM
jackarse's Avatar
I'm a Jackass
need more help!
Old Dec 23, 2004 | 09:37 PM
cnyej1's Avatar
Dont bump after only 1 minute. Check the fuses again....
Old Dec 23, 2004 | 09:59 PM
huntarrr's Avatar
Default Re: **HELP** tail light prob!! EG tech pro's plz help! (cnyej1)
check the fuses again, then check the wiring... this seems pretty obvious....
Old Dec 24, 2004 | 12:53 AM
SjCiViCHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spunky424 &raquo;</TD></TR><TR><TD CLASS="quote">any chance was the car automatic then converted to manual? if so you have to wire the reverse lights yourself...</TD></TR></TABLE>
how do you wire it yourself? i had an auto to manual swap done on my car, and before it used to work, but it went out one day.
Old Dec 24, 2004 | 01:07 AM
acefabric's Avatar
Default Re: **HELP** tail light prob!! EG tech pro's plz help! (SjCiViCHB)
Did you just put in a new radio or do anything to the wiring of the deck?
Old Dec 24, 2004 | 01:20 AM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGcellent &raquo;</TD></TR><TR><TD CLASS="quote"> i guess it must be the fuses then.. i'll triple check it again tomorrow.. </TD></TR></TABLE>
dont just look at them, they can be diceving... check it with a test light. thats the ONLY way to know if a fuse is good.
Old Dec 24, 2004 | 06:02 AM
EG6R's Avatar
Id like to know too. Mines off more than its on. But recently they are not working at all. All bulbs and fuses are ok.
Old Dec 24, 2004 | 06:45 PM
acefabric's Avatar
Default Re: **HELP** tail light prob!! EG tech pro's plz help! (EG6R)
Well did anyone do anything to the radio or dash lately? There is a wire that you dont use when you hook up a after market deck for the dimmer and it usually grounds out or it doesnt make a complete circuit and will kill the tail lights.
Old Dec 25, 2004 | 08:41 AM
SjCiViCHB's Avatar
Default Re: **HELP** tail light prob!! EG tech pro's plz help! (dadeboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dadeboy &raquo;</TD></TR><TR><TD CLASS="quote">Well did anyone do anything to the radio or dash lately? There is a wire that you dont use when you hook up a after market deck for the dimmer and it usually grounds out or it doesnt make a complete circuit and will kill the tail lights.</TD></TR></TABLE>
well I did ghetto rig a stock deck/double din from an 00 accord into my hatch. But my lights work fine, when they blew out it was because of the fuse, but other got that fixed and everythings okay now. But my Reverse light still isn't working. Its wierd, one day it was working, and then I threw it into reverse and it was working pulled it out, and back into reverse again, and it stopped working.
Old Jan 31, 2005 | 01:47 PM
jackarse's Avatar
I'm a Jackass
bump because its been a month and i still haven't found the problem.
7panget
Oct 19, 2007 06:14 PM
vietfella
Mar 12, 2007 09:23 PM
booja
Sep 7, 2004 10:20 AM
Mr Boston
Aug 7, 2002 08:22 PM
