Hydro tranny vs cable tranny.
Old Dec 23, 2004 | 03:01 PM
HamiltonRex's Avatar
Default Hydro tranny vs cable tranny.
do the hydro style trannys use the same style transmission mount as the cable?
IE. Can i swap a hydro tranny inplace of my cable tranny and retain the same transmission mount?
Searched to no avail.
Thanks
Old Dec 23, 2004 | 04:19 PM
WhiteDSM520's Avatar
Default Re: Hydro tranny vs cable tranny. (HamiltonRex)
No, you need a new tranny mount. Hasport makes them. I don't know if they sell them separate from the whole b-series kit though. You'll also need a new clutch disc. Hydro trannys' input shafts are different from cable.
Old Dec 23, 2004 | 04:33 PM
GSRCRXsi's Avatar
Default Re: Hydro tranny vs cable tranny. (WhiteDSM520)
no you cant use the same mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteDSM520 &raquo;</TD></TR><TR><TD CLASS="quote"> You'll also need a new clutch disc. Hydro trannys' input shafts are different from cable. </TD></TR></TABLE>
and that's not entirely correct. the transmission input shaft only varied between 90-91 and 92+. cable transmissions were still in integra's until '94. so if your transmission is a 92 or 93, then a new clutch disc wont be necessary. you would only need a new clutch disc if your cable tranny is a 90 or 91.
John The G
Transmission & Drivetrain
Mar 8, 2023 06:49 PM
viking-101
Jun 26, 2011 07:11 AM
vtec25
17
Oct 3, 2006 06:57 PM
clemsonteg
Dec 27, 2005 07:32 PM
DOHCarp
Sep 7, 2002 10:15 AM
