RADIATOR?
THIS WAS MY FIRST BUDGET SWAP, AND I CANT AFFORD A NEW RADIATOR. WILL I HAVE TROUBLE USING THE STOCK CX RADIATOR WITH A GSR? I KNOW I SHOULD REPLACE IT, BUT WILL I BE OK FOR A WHILE? SHOULD I REMOVE THE THERMOSTAT FOR THE TIME BEING? THANKS
Please turn off the caps lock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suckawillis »</TD></TR><TR><TD CLASS="quote">WILL I HAVE TROUBLE USING THE STOCK CX RADIATOR WITH A GSR?</TD></TR></TABLE>
No. Unless your current radiator is damaged and/or decrepit . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I KNOW I SHOULD REPLACE IT</TD></TR></TABLE>
Why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">BUT WILL I BE OK FOR A WHILE?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">SHOULD I REMOVE THE THERMOSTAT FOR THE TIME BEING? THANKS</TD></TR></TABLE>
No!!!
Why?
Yes.
No!!!
Should be just fine, and it doesn't hurt that it's middle of the winter either.lol A stock del sol rad works pretty good for any swap, and can usaully find one cheaper than an aftermarket unit.
the del sol dual core from autozone is great upgrade for a non B-series motor...in my experience, the neck ports where the radiator hoses connect are too small for the B series hoses, it's next to impossible to get them not to leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xZeler8 »</TD></TR><TR><TD CLASS="quote">the del sol dual core from autozone is great upgrade for a non B-series motor...in my experience, the neck ports where the radiator hoses connect are too small for the B series hoses, it's next to impossible to get them not to leak</TD></TR></TABLE>
You are on crack I got a B series sitting in my garage with dual core, no leaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">
You are on crack I got a B series sitting in my garage with dual core, no leaks.</TD></TR></TABLE>
same here
same here
