no heat no air coming out of the vents
Old Dec 23, 2004 | 01:31 PM
crxvtecturbo's Avatar
* B A N N E D *
Default no heat no air coming out of the vents
when i turn my car on and turn the climate control on i hear nothing and nothing is blowing out of the vents i checked the fuses and they are good do you think the the blower motor went bad
Old Dec 23, 2004 | 01:32 PM
* B A N N E D *
Default Re: no heat no air coming out of the vents (crxvtecturbo)
ok today i changed the resistor and it still did not work. Then i took the whole blower motor out and i jumped the blower motor and it works. Some people say you have to take out the dash to get to it you dont because i did it without taking the dash out. Is there any other fuses besides the 30 amp under the dash?
Old Dec 23, 2004 | 03:10 PM
ef8 h0!'s Avatar
do a volt reading on the wires to the motor and make sure you have voltage at the end of the wires. the voltage should go up and down when you move the switch.
Old Dec 23, 2004 | 03:47 PM
* B A N N E D *
Default Re: no heat no air coming out of the vents (bernie'sb16crx)
where is the fuse under the hood at?
Old Dec 23, 2004 | 09:00 PM
* B A N N E D *
could my switch on the climate control go bad?
Old Dec 23, 2004 | 09:05 PM
Vtec_TrackMan's Avatar
do what bernie'sb16crx said could be a voltage drop.
Old Dec 23, 2004 | 09:12 PM
* B A N N E D *
Default Re: no heat no air coming out of the vents (Vtec_TrackMan)
I checked the voltage and it is fine
Old Dec 24, 2004 | 10:08 AM
* B A N N E D *
ttt
Old Dec 24, 2004 | 10:18 AM
EL Vap133's Avatar
2 threads on the same thing?
civicej897
12
Apr 4, 2013 08:23 PM
GeorgeA
Feb 20, 2013 05:30 PM
Bangher4$
Honda Civic (2001 - 2005)
11
May 22, 2009 01:25 PM
ED6JDM
Oct 15, 2006 06:45 PM
crxvtecturbo
26
Jan 9, 2005 07:57 PM
