Kyb AGX shocks adjusting question
Old Dec 23, 2004 | 10:59 AM
Undercover_Skank's Avatar
Default Kyb AGX shocks adjusting question
i got these with the car and i dont know how im supposed to adjust them...ive searched and couldnt find anything really...so yeah...
what kind of settings should i leave it on?
for the streets or for the tracks....?
and what settings do you guys leave it on?
its with tien springs by the way....thanks
Old Dec 23, 2004 | 11:04 AM
AutoXer's Avatar
Default Re: Kyb AGX shocks adjusting question (Vietvicious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vietvicious &raquo;</TD></TR><TR><TD CLASS="quote">i got these with the car and i dont know how im supposed to adjust them...ive searched and couldnt find anything really...so yeah...
its with tien springs by the way....thanks</TD></TR></TABLE>
Start out with 1/2 stiff on each. Then if you actually take it to a track, you might try stiffening the rear to get it to oversteer a bit and see how that helps.
Old Dec 23, 2004 | 11:09 AM
JDMSiGuy17's Avatar
Well you can set it to any setting that you want. I have them on my car but it depends how stiff or soft you want them for the street or strip. The fronts should adjust from the top of the shock under the hood. It should range from 1-4 1 being softest and 4 being stiffest. Then for the rears it adjust more towards the base of the shock with a ****. It should range from 1-8 again 1 being the softest and 8 being the stiffest. At the track I would recommend 1 in the front and 8 in the back its suppose to help prevent wheel hop and rear end squating on the launch.But for the street it is really up to what you like riding on. Hope this answers your questions and if you have any more just ask and ill try and help. Good luck.
Old Dec 23, 2004 | 11:11 AM
what settings do you guys have it on for the streets??? just for a good ride...and mine adjust from the top in the back also..i havent checke if theres a **** at the bottom
Old Dec 23, 2004 | 11:15 AM
JDMSiGuy17's Avatar
Default Re: (Vietvicious)
Since I dont race on the streets I dont need them to be stiff so I usually just leave them on one all the way around but your comfortable ride is different from everyone elses and what spring you are using makes a difference also. But just test out what fells the most comfortable for you.
Old Dec 23, 2004 | 11:18 AM
yeah...it was on 2 in the front and 1 in the back....i dont like the ride at all..i just want to have a pretty smoothe ride for the streets....i was thinking of getting new springs...but thanks for the help
Old Dec 23, 2004 | 11:22 AM
JDMSiGuy17's Avatar
What type of teins do you have the H-Type or the S-Type cause I was looking into getting some S-Type springs and putting them on my car. My car rides way too bouncy and I wanted something smoother.
Old Dec 24, 2004 | 01:55 PM
im not sure...i think its the s-tech...it came with the car....
Old Dec 24, 2004 | 02:00 PM
Unjockable's Avatar
New User
The AGX products have the following approximate damping force values.
When adjusted, both rebound and compression damping forces change.
Setting#:
Relative Value
1 - Same as Factory 100
2 - Same as our GR2 products (10~15% firmer than Factory) 115
3 - 50% firmer than #2 172
4 - 30% firmer than #3 223
For an eight position adjustable product, the damping force values are
approx.
the following:
With #2 being Factory at a relative value of 100,
#1 = 95 (5% softer than Factory #5 = 143.5 (43.5% firmer
than Factory)
#2 = 100 (Factory damping force) #6 = 172 (72% firmer
than Factory)
#3 = 107.5 (7.5% firmer than Factory) #7 = 197.5 (97.5 firmer
than Factory)
#4 = 115 (15% firmer than Factory)(GR-2) #8 = 223 (123 %
Old Dec 24, 2004 | 02:10 PM
blackeg's Avatar
Default Re: (Unjockable)
i recommend h&r race with the agx's. i have them on my civic, and when set at 1 in the front and 3 in the rear the ride is so perfect.
as for your current situation, try 2 in the front and 2 or 3 in the rear. thats how my ej1 was setup and if i had better springs it woulda been sweet
Old Dec 24, 2004 | 04:37 PM
JDMSiGuy17's Avatar
Default Re: (blackeg)
blackeg how low does ur car sit on the H&R springs. I pretty much want to be as low as I can on the springs without sacrificing ride comfort and without cutting the springs. I like how low my car sits on the coilovers I have on my em1 right now but I want a smoother ride. How much do the H&R springs run?
Old Dec 24, 2004 | 04:56 PM
ek9800's Avatar
Default Re: (JDMSiGuy17)
i have my front set on 3 and my rear set on 6 i believe...its not that bad of a ride its ok.. btw its daily driven like that
Old Dec 26, 2004 | 09:08 AM
trrbl1bmx's Avatar
i bought the agx's for my 89 civic si but im not quite sure what coilovers to go with. im trying to achieve the "stiff as hell feel" any one have suggestions, pics of their ef with agx's
Old Dec 26, 2004 | 09:19 AM
blackeg's Avatar
ive got about a finger's gap between top of the tires and the fenders
Old Dec 26, 2004 | 09:29 AM
turbotime's Avatar
i have agx+ground control and i love it.
I run 2 in front and 1 in back on the streets and althought you can tell they are 'sport' suspension, the ride is pretty nice.
I got the kind that is 4way all around. I LOVE THEM AGX ALL THE WAY
Oh yeah, also, agx suck for real low-rides, if you plan to go lower than 1.5" get the ground control upper mounts, they extend shock travel and let u go lower. Or you can make them urself, but if uve got the money just buy em. Idid and i loveem
Old Dec 26, 2004 | 09:49 AM
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">
Oh yeah, also, agx suck for real low-rides, if you plan to go lower than 1.5" get the ground control upper mounts, they extend shock travel and let u go lower. Or you can make them urself, but if uve got the money just buy em. Idid and i loveem</TD></TR></TABLE>
how do the upper mounts look like????
Old Dec 26, 2004 | 11:02 AM
turbotime's Avatar
http://www.ground-control.com/...3351a
Old Dec 26, 2004 | 11:43 AM
thenick's Avatar
how does one tell if an AGX is blown?
does the car have to be elevated when changing it or can one do it on the ground?
Old Dec 26, 2004 | 12:57 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vietvicious &raquo;</TD></TR><TR><TD CLASS="quote">yeah...it was on 2 in the front and 1 in the back....i dont like the ride at all..i just want to have a pretty smoothe ride for the streets....i was thinking of getting new springs...but thanks for the help</TD></TR></TABLE>
Try 2 in the front and 4 in the back for street driving, if you want it slightly firmer, go 3 front and 5 in the back, that's what my AGX's are set at and the car handles great.
Old Dec 26, 2004 | 02:03 PM
AutoXer's Avatar
Default Re: (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
Try 2 in the front and 4 in the back for street driving, if you want it slightly firmer, go 3 front and 5 in the back, that's what my AGX's are set at and the car handles great.</TD></TR></TABLE>
Doesn't that give you oversteer in slippery conditions? I'm running 1/2 stiff on my fronts, 3/4 stiff on the rears with a comptech swaybar. I'm thinking of putting the sway on soft (it's medium now) and setting the shocks all to 1 to avoid any adverse handling in the winter.
Old Dec 26, 2004 | 02:08 PM
RF's Avatar
RF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Try 2 in the front and 4 in the back for street driving</TD></TR></TABLE>
i have the same setup for street driving. feels great.
Old Dec 26, 2004 | 03:30 PM
blackeg's Avatar
i would not say that they suck for low rides. im lowered about 2.25 and they ride very well. however, they are not warrantied for lower than 1.5"
Old Dec 26, 2004 | 03:54 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
No not at all, softening up the rear shocks helps keep the rear end planted a little better, similar to dropping the rear tire psi a couple pounds. I don't drive my car in anything slipperier than rain (it's stored in the winter) and my settings haven't caused me any handling problems in respect to oversteer. Some fwd's have problems swapping ends in slippery weather when braking but all Canadian EM1's like mine come equipped with ABS standard so i never have any troubles that way either.
Old Dec 26, 2004 | 04:38 PM
thenick's Avatar
Default Re: (thenick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">how does one tell if an AGX is blown?
does the car have to be elevated when changing it or can one do it on the ground?</TD></TR></TABLE>
Old Dec 26, 2004 | 06:13 PM
AutoXer's Avatar
I don't drive my car in anything slipperier than rain (it's stored in the winter) and my settings haven't caused me any handling problems in respect to oversteer. </TD></TR></TABLE>
Thanks so much for your response; I always trust your replies. I wish the above was the case for my car. I drive my tack ***** on a daily basis. This is the first winter that I've had a swaybar and an adjustable suspension. My settings that I'm running with now (that I stated above) give me a neutral to oversteer handling when I'm on the track.
I've been running with a lower PSI in the rear, but I'm worried about the 'snap-on' oversteer that my setup has been prone to. I'm thinking that I'll leave the front at 1/2 stiff, and soften the rear to the 1/8 setting. I'm thinking that that, in combination with the lower PSI in the rear, will help the car from doing anything that I wouldn't want it to this winter.
