obd1 to obd2 conversion...is it possible
Old Dec 23, 2004 | 10:06 AM
ebp_dc2's Avatar
Default obd1 to obd2 conversion...is it possible
Ok, i got a 1998 integra with a 95 jdm h22a. New emissons in New York are about to bend me over if you know what i mean. It is illegal to have a car 1997 or newer running obd1. Somehow i need to convert my car to obd2. I need to know exactly what parts need to be swapped to make my car obd2. Please no posts that say, get a new engine, blah blah. Exact parts please
thanks
Old Dec 23, 2004 | 11:42 AM
ohboy95c's Avatar
Default Re: obd1 to obd2 conversion...is it possible (h22d dc2)
http://www.boomslang.us/order.htm
Quick search found me this, about 10$ more than usual
Old Dec 23, 2004 | 11:49 AM
eda6's Avatar
Default Re: obd1 to obd2 conversion...is it possible (ohboy95c)
I know you need a obd1 to obd2 conversion harness and a obd2 ecu. The existing distributor will work. You might need a new o2 sensor. I think obd2 o2 sensors are five wire and obd1 o2 sensors are 4 wire.
Old Dec 23, 2004 | 11:55 AM
ebp_dc2's Avatar
anyone got any more info??
Old Dec 23, 2004 | 12:45 PM
perlmeister8's Avatar
Default Re: obd1 to obd2 conversion...is it possible (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">I know you need a obd1 to obd2 conversion harness and a obd2 ecu. The existing distributor will work. You might need a new o2 sensor. I think obd2 o2 sensors are five wire and obd1 o2 sensors are 4 wire.</TD></TR></TABLE>
No, obd2 sensors are 4-wire.
Old Dec 23, 2004 | 01:23 PM
suckawillis's Avatar
Default Re: obd1 to obd2 conversion...is it possible (perlmeistere81)
I GOT AN ECU FOR YOU........
Old Dec 23, 2004 | 01:35 PM
ebp_dc2's Avatar
well id taek teh ecu from you, but i need to know exactly the parts i need first...once more ppl tell me exactly what i need ill let you know
Old Dec 24, 2004 | 09:08 AM
ebp_dc2's Avatar
Default Re: (h22d dc2)
need more help please someone i need more info asap
Old Dec 26, 2004 | 02:03 PM
ebp_dc2's Avatar
need info hlep me out!!!
Old Dec 26, 2004 | 07:55 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22d dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, i got a 1998 integra with a 95 jdm h22a. New emissons in New York are about to bend me over if you know what i mean. It is illegal to have a car 1997 or newer running obd1. Somehow i need to convert my car to obd2. I need to know exactly what parts need to be swapped to make my car obd2. Please no posts that say, get a new engine, blah blah. Exact parts please</TD></TR></TABLE>
You are going to need the OBD2 oil pump with the CKF sensor on it. You will need the secondary O2 sensor installed as well. Basically all the OBD2a stuff that is needed and present on the H22a will need to be there. Most of the other sensors on that motor are ok. You will also need to source the OBD2a ecu for this setup as well.
Old Dec 27, 2004 | 06:17 AM
tgreaves's Avatar
Anything is possible but why?
Old Dec 27, 2004 | 10:15 AM
ebp_dc2's Avatar
Default Re: obd1 to obd2 conversion...is it possible (tgreaves)
because in new york 1998 or newer needs to be obd2 for inspection...how much you think im lookin at for the parts needed?? price wise
Old Jan 2, 2005 | 07:06 PM
ebp_dc2's Avatar
bump
DAP97SI
Mar 1, 2012 05:10 AM
emooheo
Mar 13, 2010 12:37 PM
silentkid
Dec 18, 2008 11:30 AM
spnbb2
Jul 4, 2004 01:02 PM
92civic_si
16
May 6, 2004 02:50 PM
