CRX with B16 on PR3 What is your setup with Fuel pressure.
Old Dec 23, 2004 | 09:43 AM
EFSiR's Avatar
Default CRX with B16 on PR3 What is your setup with Fuel pressure.
I'm finding this issue a bit confusing. I'm refering to the helm's manual that specifies fuel pressure for JDM B16 with PR3/PW0 ECU.
It says that the results for proper fuel pressure should be:
- engine IDLING
- regulator vacuum hose disconnected and pinched.
With this condition, I'm assuming that you want to plug up the manifold as this will cause the RPM to fluctuate b/w idle and 1500RPM, Right?
- pressure of 35-41 PSI
I'm having a bit of an issue with this as looking at B17 motor for example, you should have 48-56 PSI with engine idling and vacuum hose disconnected and pinched. The ITR USDM calls for 47-54PSI.
So, should B16 operate on that low of a fuel pressure? I guess I'm having hard time accepting that 200cc difference in displacement could call for 10 PSI of a fuel pressure dropp.
TIA
Old Dec 23, 2004 | 10:34 AM
Reelizmpro's Avatar
Default Re: CRX with B16 on PR3 What is your setup with Fuel pressure. (EFSiR)
Shouldn't it be around 42-44psi?
Old Dec 23, 2004 | 11:31 AM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR &raquo;</TD></TR><TR><TD CLASS="quote">With this condition, I'm assuming that you want to plug up the manifold as this will cause the RPM to fluctuate b/w idle and 1500RPM, Right?
Just disconnect the vacuum hose from the fuel pressure regulator. Idle will raise and stay steady. This simulates a full load condition (pedal to the floor). No need to plug up the manifold. Set your fuel pressure to 35-41 (vacuum hose off) on a stock motor. I have i/h/e/70mm tb/itr intake manifold. I run 46-48 psi of fuel.
It says 35-41 psi for the b16 in my 90 crx honda service manual.
Old Dec 25, 2004 | 10:31 AM
EFSiR's Avatar
Default Re: CRX with B16 on PR3 What is your setup with Fuel pressure. (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
Is this fuel pressure a result of dyno tuning?
TIA
b18LS
Sep 28, 2006 08:18 PM
VspecSiR
Jun 26, 2006 04:59 AM
johnnylaw
Apr 26, 2006 02:05 PM
QuickRexSi21
13
Feb 10, 2006 11:57 PM
delcamino
Mar 29, 2002 07:42 PM
