'02 civic tranny on a d16y8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
really?
really?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">just a quick searching on dseries.org
i found a couple of posts that say no, it is not possible.
No it's not possible or no, it's not been done before?
Are you sure though? '01+ Civics use cables instead of rod linkage.
I'm sure it would bolt up to a D16Y8 no problem, but to install in a pre-'01 Civic, you'd probably have to use the cable shifter as well.
I wonder if the transmission cases are the same? You may be able to swap the 4.4:1 final drive into an older D-series trans case.
No it's not possible or no, it's not been done before?</TD></TR></TABLE>
i read that it is not possible at all.
the new d17's are d series but are not compatible with any older stuff i what heard. arent those motors turned around with the intake in the front of the car, or is that only the k series?? if thats tru then they def will not work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beaver EJ1 »</TD></TR><TR><TD CLASS="quote">the D17's still have the same orientaiton as other D series, as with the intake in the back, exhaust in front.</TD></TR></TABLE>
ok, wasnt sure...but i heard that using parts from one on the other wont work (d16y8 head on d17block)
would be nice if it did tho
