Will ITR 96 brake direct bolt on to 95 Civic Coupe DX?
Old Dec 22, 2004 | 10:53 PM
EGGTS's Avatar
Default Will ITR 96 brake direct bolt on to 95 Civic Coupe DX?
Did a search but still not sure, so instead of spending hours to read through the post, i just post a new thread.
I am sure someone did this conversion. Just want to make sure it is a direct bolt on to a 95 Civic DX Coupe except you need a wheel with 4x114.3 bolt. If it involves in replacing any parts, would someone tell me what I need?
Thanks
BC
Old Dec 23, 2004 | 09:13 AM
EGGTS's Avatar
Default Re: Will ITR 96 brake direct bolt on to 95 Civic Coupe DX? (EGGTS)
Anyone please confirm to me please.
Thanks
Old Dec 23, 2004 | 09:30 AM
94eg!'s Avatar
#1 Super Guy
Loved
Everything should bolt right on, with the exception of the LCA's (unless you use the ITR shocks too). You should also convert your 30/30 proportioning valve (if your non-abs) to a 40/40 from a "rear-disc" (non-abs) civic 92-95, del sol 93-97 or integra 94-01.
You will also need a larger Master Cylinder, otherwise stock 13/16ths unit won't move enough fluid. The 15/16ths unit from the 91 civic EX 4 door will bolt right on, and work perfect.
Good luck...
Old Dec 23, 2004 | 10:19 AM
EGGTS's Avatar
Default Re: Will ITR 96 brake direct bolt on to 95 Civic Coupe DX? (94eg!)
Thanks for reply. The LCR are you refering to the rear or the front. I have Tein SS on my DX coupe, will the suspension works? I have ITR mastercylinder and 40/40 proportion valve in hand already.
Thanks
BC
Old Dec 23, 2004 | 11:35 AM
MR5sARECOOL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGGTS &raquo;</TD></TR><TR><TD CLASS="quote">Did a search but still not sure, so instead of spending hours to read through the post, i just post a new thread. </TD></TR></TABLE>
Is this what you meant to say:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGGTS &raquo;</TD></TR><TR><TD CLASS="quote">"I did a search but was not sure so instead of spending 2 minutes of my time looking, I'd rather be lazy......"</TD></TR></TABLE>
<FONT SIZE="3">Look in the FAQ's</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda-tech.com &raquo;</TD></TR><TR><TD CLASS="quote">
<FONT SIZE="3"> ***Post Links to Helpful FAQs So We Can Get an Archive Going***</FONT>
Old Dec 23, 2004 | 02:38 PM
EGGTS's Avatar
Default Re: Will ITR 96 brake direct bolt on to 95 Civic Coupe DX? (MR5sARECOOL)
There are tons of post about this conversion which is all over the places. I am sure someone very helpful, nice and friendly will reply to me and confirm that. This is a forum for information and everyone is free to post for any kind of question. If you think it a stupid post, please don't reply.
Thanks
BC
skiddish
Oct 11, 2009 01:11 AM
crackercr-x
Apr 9, 2005 11:31 PM
Integra_Boi
Aug 12, 2003 08:52 PM
