Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Fuel burn rates
Old Dec 22, 2004 | 07:08 PM
turfer's Avatar
Default Fuel burn rates
We are working on an open class endurance project and we would like to get some data on fuel burn rates (minutes per gallon). Specifically from the fully prepped racers that are seeing 200+whp. Please include displacement, approx whp, and basic engine configuration/type.
Thanks,
Rick
Old Dec 22, 2004 | 07:21 PM
Track rat's Avatar
Default Re: Fuel burn rates (turfer)
Honda Challenge H2 Integra R, 1.8 liter B18C5, stock internals with Toda header, AEM intake tube and K&N filter, Apexi VAFC tuned slightly leaner at high RPMs. Approx 210 HP at crank, 185 hp @ wheels. Burns about 10 gallons in 70 minutes. (1 gallon in 7 minutes).
Old Dec 23, 2004 | 06:20 AM
Raceworks's Avatar
We've run 1.6, 1.8, 2.0, and 2.3 engines with 200-215 at the wheels. If you're not running high compression and don't mind running pretty lean, you can get down into the 7 gallons per hour range with a near-stock B16A.
The configuration we were running at the 13hr (B18 block w/B16 pistons & head, Skunk Stage 1 cams, ported head, SMS header, 2.5" exhaust w/two Dynomax flow-through mufflers), we were burning about 9 gallons in 1hr 7min.
Old Dec 23, 2004 | 05:27 PM
turfer's Avatar
Default Re: Fuel burn rates (Raceworks)
Wow, I am surprised. We barely get 7 min/gal in our ITA CRX. I had been guessing it would be closer to 5.5-6 min/gal.
Thanks. Anyone else?
Rick
Old Dec 23, 2004 | 08:05 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turfer &raquo;</TD></TR><TR><TD CLASS="quote">Wow, I am surprised. We barely get 7 min/gal in our ITA CRX. I had been guessing it would be closer to 5.5-6 min/gal.
Rick
1 gallon in 5.5 minutes. 295 WHP turbo B18C5 (stock motor).
Data point at Road America, 4.5 gallons in 25 minutes. A/F ratio was between 11.0-11.5:1. About 70 degrees ambient temperature. Some time was spent coasting behind slow M3's and 911's.
-Chris
Old Dec 24, 2004 | 10:34 AM
Weston's Avatar
approximately 1 gallon in 8 minutes when road racing for my 200whp/192 torque turbo B18B @ 7 psi... 12.5:1 AFR, small T3 turbo (no lag; road racing build), and 2.25" cat-back exhaust.
Old Dec 24, 2004 | 09:02 PM
pmachan's Avatar
Default Re: (Weston)
1 gallon in about 2 minutes.
358 cu in V8, close to 500 whp, revs to 7500
Old Dec 24, 2004 | 11:24 PM
slammed_93_hatch's Avatar
Default Re: (pmachan)
in an H4 93 civic EX we were getting 10 gallons about every 1 hour and 20minutes minimum, up too 10 gallons every 1 hour and 45 minutes. It really vaired threw out the 25 hours
Old Dec 28, 2004 | 10:55 AM
turfer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pmachan &raquo;</TD></TR><TR><TD CLASS="quote">1 gallon in about 2 minutes.
Got me, doh. How about your Honda?
More from the H1 and HondaCup guys?
Rick
Old Dec 28, 2004 | 11:53 AM
Littleton's Avatar
Default Re: (turfer)
H1 B16, shifting at 8700
around 11 gallons per 1 hr and 15 minutes.
Based off of Enduro data
atec
Dec 10, 2014 01:38 AM
brokenojoke
Engine Management and Tuning
16
Aug 4, 2009 05:13 PM
TypeR0149
Mar 6, 2002 10:25 AM
way2slow
Jul 11, 2001 06:54 PM
