Battery might be bad, but less than a year old
I think my battery might be going bad, but I wanted to get the opinion of people on here first, seeing that the battery is less than a year old (I think I still have the warranty info and what not).
My 1992 4D Accord EX wouldn't start. Did a voltmeter test, battery was at 10.5. Gave it a jump, ran fine. Tested it while idle and everything else off, the volts sat at about 14.5. The thing that bothered me was that with defroster, lights, heat, and my after market radio on, volts dropped to 10.5, which I thought was pretty low (is it?). So I went back into the car, turned everything off, volts climbed back up.
After I turned the car off, I watched as the volts feel all the way back down to about 10.5.
Is this a battery problem? Perhaps some power is being "leaked" by my after market radio (there shouldn't be, its been in there for two years or so)?
Sounds like the alternator to me, because the car should never need to touch the battery while the alternator is providing power. Especially since the voltage dropped under full load. I'd go over to autozone and get the battery and alternator tested (should be free) and see how that turns out. Good luck though!
I was thining Alternator as well, but I wasn't sure. Thanks a bunch though, I'll hitup AZ tomorrow. I hope its just a battery.
I would guess alternator also. I have had cells go bad in batteries though that have less than a year old. But in your case probably the alternator.
i think its ur alternator also...i hope it aint been inna wreck..if it has and thats when ur problen occured maybe ur grounds not good...anyways is ur alternator makin any loud noise...somtimes u can hear if ur alternator is goin bad...to really make sure where the noise is coming from use a screwwdriver..put it on the alternator and put ur ear on the screw driver and listen...sounds like grinding noise..then ur alternator...those are ussually the sighn
vtecnique69
Honda Civic (2006 - 2015)
Nov 7, 2014 08:18 AM
HybridHatchC1
22
Dec 11, 2004 10:35 PM
