i'm burning through my 16 and 18 gauge steel pipes
I'm making a custom exhaust and i don't know why i'm burning through the pipes. I'm using the red top tungsten and it's about 3mm out of the ceramic tip or i was told that it might because of my electrode. What should i use when welding thin metals? i have a daytona mig pocket pulse tig welder..if that helps..
yeah, turn the amps down. if you have a pedal regulator/on-off switch that will help a lot.
if your scratch starting, have a buddy or someone at the dial. basically you'd want the amperage where you can hold it in one spot for like 20 seconds and not burn through.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markdman »</TD></TR><TR><TD CLASS="quote">basically you'd want the amperage where you can hold it in one spot for like 20 seconds and not burn through.</TD></TR></TABLE>
Are you sure about that?? Definatly not how i weld.
in the mighty words of tim "the toolman" taylor. Hruuuuh?!
^ Disagree. There is a right and wrong way to do things. If that guy welds pipe like that i bet i could give one of his welds one wack with hammer and it would break right off.
did i say his was right or wrong no read understand think about what your typing
I understand that you are the welding expert mr hammer wacker
obviously @ the opposite ends of the spectrum there is a right and a wrong but if he is producing a good weld and has acclamated to do it a certain way then so be it.
i know i don't weld exactly the same as our welder does (and his is damn near perfect) the way i do things is just more comfortable for me.
There isnt one way to do things its not cut and dry done deal.
and if your saying a weld doen wtih 30 amps will break i will be mroe then happy to send you soem stainless i welded for you to wack away at
But i guess its wrong to have your own methods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 »</TD></TR><TR><TD CLASS="quote">im not saying any is right or wrong
Modified by eLusive ek4 at 5:29 PM 12/23/2004</TD></TR></TABLE>
ok buddy, nice way to edit that in after i posted. next time i'll be sure to quote your original statement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 »</TD></TR><TR><TD CLASS="quote">did i say his was right or wrong no read understand think about what your typing</TD></TR></TABLE>
umm ok. thanks for the advice.
Anyways i was talking about this. I think your the one who is misunderstood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy »</TD></TR><TR><TD CLASS="quote">If that guy welds pipe like that i bet i could give one of his welds one wack with hammer and it would break right off. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 »</TD></TR><TR><TD CLASS="quote">But i guess its wrong to have your own methods </TD></TR></TABLE>
There's 2 ways to do everything. My way and the wrong way.
Oh...and 10 amps isn't going to weld it well, if at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid »</TD></TR><TR><TD CLASS="quote">
Oh...and 10 amps isn't going to weld it well, if at all. </TD></TR></TABLE>
oh shush you!
oh shush you!
luder94-ChrisA
13
Dec 2, 2004 11:15 AM
