Lincoln invertec 205V
what thickness (aluminum) can you weld with this machine?
http://www.weldingmart.com/Qstore/p001709.htm
Thanks.
Thanks.
Sir, depends on what? I'm new to alum welding (not to steel TIG welding) , hope you can help......
Thanks
Thanks
Aluminum requires different amounts of heat depending on the size of the part you're welding. This machine can put out 200A, so it should do 1/4" nicely, but larger parts might need preheating before welding.
AG, thanks for your input.
I do mostly intercooler plumbing, end tanks and other small things, so usually maximum of 1/4 thickness.
Do you know of any other that can handle little more than 1/4 thickness with about the same price?
Ifnot, i'll buy the v205 machine.
Thanks anyways
Thanks anyways
streetimports
Oct 18, 2004 02:21 PM
streetimports
Jul 22, 2004 01:20 PM
1CiViC1
Nov 27, 2003 09:27 PM
TurBoXBirD16
Jun 30, 2002 05:59 AM
