wats the difference from obd0 and obd1
Old Dec 22, 2004 | 01:46 PM
HondaEF8R's Avatar
Default wats the difference from obd0 and obd1
i was wondering wats the difference from obd0 and obd1?
Old Dec 22, 2004 | 02:00 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: wats the difference from obd0 and obd1 (HondaEF8R)
Honda's and Acura's did not have on board diagnostics (sp) in their cars for 91 and older models. In 1992 the 1st gen ....OBDI came out for improved emmisions. OBDI ecu's are very easy to reprogram making them the most popular for engine swaps and precise tunning. Even guys with OBDII (came out in 96) often go back to obdI for reprograming purposes.
Old Dec 22, 2004 | 05:14 PM
mikerbike's Avatar
Default Re: wats the difference from obd0 and obd1 (Deetz)
I still don't understand why they called it 'on-board'. Before 92, you could just look at the light to figure out what's wrong. 92-up, don't you have to cross some wires or something? Pre-Obd was less work and was truly 'on-board'. Oh well, Maybe I'll learn when I'm older.
Old Dec 22, 2004 | 05:23 PM
4DRmafia's Avatar
so ur saying all ef are obd 0 or i thought in some ef who have a si system are obd 1 ?
EP3_05's Avatar
Default Re: wats the difference from obd0 and obd1 (mikerbike)
For pre-91 honda and acura cars the trouble codes are read by counting the number of flashes generated by the led located inside the ecu. For the newer 92+ models the trouble codes are read by jumping a connector under the hood(i believe) and then counting how many times the CEL flashes on the dash.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">so ur saying all ef are obd 0 or i thought in some ef who have a si system are obd 1 ?</TD></TR></TABLE>
All pre-91 civic/crx models are obd0
Old Dec 22, 2004 | 05:28 PM
4DRmafia's Avatar
what is the best to have obd0 obd1 obd2?
Old Dec 22, 2004 | 05:29 PM
4DRmafia's Avatar
i'm sorry fellas i just never really find out what different between then until now
Old Dec 22, 2004 | 05:32 PM
EP3_05's Avatar
Default Re: (SkipMic2006)
The "best" OBD would be probably be OBD1 since it is the easiest to work with and modify. However, it all depends on what engine the car has.
Old Dec 23, 2004 | 05:23 AM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">so ur saying all ef are obd 0 or i thought in some ef who have a si system are obd 1 ?</TD></TR></TABLE>
no honda/acura before 92 has obd1. i think what you are thinking about is MPFI. the Si and ex have MPFI but the dx and STD have dpfi but both are obd0.
Old Dec 23, 2004 | 07:00 AM
doublethink's Avatar
Default Re: (ham)
the reason obd 1 is so powerful is it has the ability to STORE codes. with the older system, once you turn the car off and then back on, if it is an intermittent problem, lets say the code goes away for a while, the LED wont flash. this can be maddening if your trying to lock down a problem that happens only when your doing 60 down the hyway.
also hondata just discontinued all their tuning options for obd0. you can still get zdyne tho, thank god.
Old Dec 23, 2004 | 07:25 AM
ham's Avatar
ham
Default Re: (doublethink)
my o2 is bad on my crx and the code only throws when im downshifting. it would be nice to look at the codes while the car was off.
Old Dec 23, 2004 | 07:49 AM
wompwomp61's Avatar
even i'm upset at this one. i wondered this a little while back. and it took me all of 5 seconds to find the answer once searched.
https://honda-tech.com/zerothread?id=1028824
ALL your answers about OBD0/1/2 are right there
golf-mk3
Sep 18, 2010 09:43 AM
clubef9
Oct 4, 2007 07:15 PM
4dOoR-Ex
Jan 29, 2007 01:25 PM
4drEF
10
Aug 26, 2004 10:04 AM
gethighonsi
Jun 20, 2003 04:21 PM
