3rd Gen 1988 Accord Lxi - Front hub
Pardon my mencing of terms if I do so... I need to replace the driver's side front hub. It makes a roaring noise when driving and I have confirmed it is not the CV joint.
Will the entire hub need to be replaced? Or is there a repair kit for the hub assembly? Just not sure what to do...
Sorry for the newbie question.....
http://www.3geez.com is more help for 3rd gens then around here...
you can go to most any parts store and get a new hub... you may have to have it pressed out at a machine shop...
the rear mount is pretty easy, too... support the motorset, unbolt the motor mount, lift the motor up enough to clear the mount and swap them out...
Derick
Derick
