heat is not working
Old Dec 22, 2004 | 01:27 PM
crxvtecturbo's Avatar
* B A N N E D *
Default heat is not working
when i turn my car on and turn the climate control on i hear nothing and nothing is blowing out of the vents i checked the fuses and they are good do you think the the blower motor went bad
Old Dec 22, 2004 | 01:42 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: heat is not working (crxvtecturbo)
That or possibly the speed resistor..
Go here for troubleshooting help:
http://www.binghamtonlife.com/...r.htm
Old Dec 22, 2004 | 02:13 PM
* B A N N E D *
Default Re: heat is not working (88DXCRX)
if it was the resistor would it still come on and feel a little air because when i turn my control on i dont feel or hear anything
Old Dec 22, 2004 | 06:34 PM
* B A N N E D *
ttt
Old Dec 22, 2004 | 08:47 PM
1RMDave's Avatar
i'd say blower motor. Just go to a wrecker and get one for cheap.
Old Dec 23, 2004 | 12:43 PM
* B A N N E D *
Default Re: heat is not working (1RMDave)
ok today i changed the resistor and it still did not work. Then i took the whole blower motor out and i jumped the blower motor and it works. Some people say you have to take out the dash to get to it you dont because i did it without taking the dash out. Is there any other fuses besides the 30 amp under the dash?
Old Dec 23, 2004 | 01:05 PM
* B A N N E D *
Are there any fuses under the hood?
Old Dec 24, 2004 | 10:09 AM
* B A N N E D *
please help me fellow honda tech people it is cold and it ried everything
Old Dec 24, 2004 | 12:58 PM
xsvfun's Avatar
Go here: http://tech.hybridgarage.com/tech/manuals/
and download the EF service manual.
Page 449 of the file is where the troubleshooting flowchart for the heater blower unit starts.
Jake
Old Dec 25, 2004 | 09:00 AM
* B A N N E D *
Default Re: heat is not working (xsvfun)
i need help!
Old Dec 27, 2004 | 06:19 PM
* B A N N E D *
bump!
Old Dec 27, 2004 | 06:41 PM
didyouhearthat's Avatar
reach down and open the vent manually with your hand. Does your defrost work, and have you try it on all modes and temps?
Old Dec 27, 2004 | 07:02 PM
* B A N N E D *
Default Re: heat is not working (didyouhearthat)
i am not getting anything out of the vents i have tried everything
Old Dec 27, 2004 | 07:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxvtecturbo &raquo;</TD></TR><TR><TD CLASS="quote">i am not getting anything out of the vents i have tried everything</TD></TR></TABLE>
Then the only other rational choice you have left is to buy a bus pass.
Old Dec 27, 2004 | 07:18 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by didyouhearthat &raquo;</TD></TR><TR><TD CLASS="quote">
Then the only other rational choice you have left is to buy a bus pass. </TD></TR></TABLE>
i asked for help on this problem not because i need a buss pass but to fix the problem as i do have have another car to drive but when the one without the heat does come out back out it will be over 600whp street driven rex sorry to go off topic so i dont think i need a buss pass i have money to buy what i want
Old Dec 27, 2004 | 08:07 PM
Rob.'s Avatar
Hmm.. best thing to do is take it into a Honda dealership and ask for the best mechanic to check it out.
Old Dec 28, 2004 | 08:15 AM
Alright, double check your fuses one more time. I had the same problem and a fuse was misplaced. Once I had the "blow" but no heat, so I reached down (under console) and opened the vent manually and the will of god filled the cabin. If you replaced the blower and whatnot I don't see why it wouldn't work. Is it even getting power?
Old Dec 28, 2004 | 08:00 PM
tealjdmcrx's Avatar
First check to see if their voltage at the plug the is inserted to the blower motor .I f their power check if their power at the plug at the fan speed switch. I had the same problem I unpluged the connector at the fuse box and checked for a proper mating between the pins. My problem was a bad connection.
Old Dec 29, 2004 | 09:06 AM
* B A N N E D *
Default Re: heat is not working (2ndgenrx)
where did you find a bad connection?
Old Jan 4, 2005 | 01:43 PM
* B A N N E D *
bump it up
Old Jan 5, 2005 | 04:24 PM
* B A N N E D *
bump it up
Old Jan 5, 2005 | 04:33 PM
doublethink's Avatar
Modified by doublethink at 2:35 AM 1/6/2005
Old Jan 5, 2005 | 04:39 PM
StorminMatt's Avatar
Does the heat itself actually work? In other words, if you go driving down the road without the blower on but the heat turned up, does hot air blow out by virtue of the car moving?
Old Jan 8, 2005 | 11:51 PM
* B A N N E D *
Default Re: heat is not working (StorminMatt)
my heat is working once again
Old Jan 9, 2005 | 03:58 PM
Well, what was it?
