B-series crx axle question..
Old Dec 22, 2004 | 12:52 PM
tgreaves's Avatar
Default B-series crx axle question..
I searched and looked at tons of posts that say many different things about what axles to use so I figured I would just ask for a straight answer..
I have an 89' crx dx with a 2nd gen jdm B16A motor.. Im using a 92-93 jdm Integra xsi ys1 b16 cable tranny on it.. What axles and intermediate shaft do I need? I dont have any axles or intermediate shafts yet..
Old Dec 22, 2004 | 01:27 PM
doublethink's Avatar
Default Re: B-series crx axle question.. (tgreaves)
axles AND int. shaft from a:
90-91 intergra (non abs)
Old Dec 22, 2004 | 01:53 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: B-series crx axle question.. (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">axles AND int. shaft from a:
90-91 intergra (non abs)</TD></TR></TABLE>
Yes, thats 100% correct! I am running the exact same set up in one of my cars, works great. Your setup should have come with the intermediate shaft though.
Old Dec 22, 2004 | 01:57 PM
tgreaves's Avatar
Default Re: B-series crx axle question.. (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, thats 100% correct! I am running the exact same set up in one of my cars, works great. Your setup should have come with the intermediate shaft though.</TD></TR></TABLE>
Why should it have came with an intermediate shaft? I bought the tranny from a friend and the motor from another friend..
Old Dec 22, 2004 | 02:56 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
Why should it have came with an intermediate shaft? I bought the tranny from a friend and the motor from another friend..</TD></TR></TABLE>
Ok, well the 92-93 Integra's came with 2nd gen B16a's and the Ys1 tranny to begine with. I thought you got the whole engine pkg minus an intermediate shaft. Every B16 pkg i've brought in for the past 7 years has included that part.
Old Dec 23, 2004 | 03:16 AM
RACINTWEEK's Avatar
90-93 teg axles and int shaft abs or non-abs doesnt matter
the ring for the speed sensor sits nowhere near the hub so it wont grind like everyone thinks, peoples axles/hubs grind because they dont take off the dust shield
Modified by RACINTWEEK at 8:02 AM 12/23/2004
Old Dec 23, 2004 | 03:40 AM
titerex's Avatar
Default Re: B-series crx axle question.. (RACINTWEEK)
you can use the 94 and up axles ( see my post ) but you need the intermediate shaft from the same year and the joint seal from the 94 if your tranny is a 90-93 and the seal of the 93 if your tranny is the 94
Exemple : axles 94 + intermédiate shaft 94 + seal 94 ( tranny 93 )
post : https://honda-tech.com/zerothread?id=1092213
Old Dec 23, 2004 | 05:48 AM
tgreaves's Avatar
Ok, well the 92-93 Integra's came with 2nd gen B16a's and the Ys1 tranny to begine with. I thought you got the whole engine pkg minus an intermediate shaft. Every B16 pkg i've brought in for the past 7 years has included that part.</TD></TR></TABLE>
Understood.. I see you have a ys1 cable in your crx with boost.. Hows the tranny gearing work out with the boost..
Old Dec 23, 2004 | 07:47 AM
hey, sorry to jack your thread man, but can you use a ys1 with a first gen b16?
Old Dec 23, 2004 | 07:55 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">hey, sorry to jack your thread man, but can you use a ys1 with a first gen b16?</TD></TR></TABLE>
I would think so..
Old Dec 23, 2004 | 08:21 AM
Deetz's Avatar
Crazy Honda Guy
Yes, of course, it will bolt right up and work like a million dollars.
Old Dec 23, 2004 | 09:09 AM
bambam's Avatar
ALSO, the intermediate shaft MUST come from a 5 spd. The axles don't matter tho. I also believe you can use 92-93 axles as long as they are the NON-ABS units.
Old Dec 23, 2004 | 10:01 AM
tgreaves's Avatar
Default Re: B-series crx axle question.. (bambam)
Just to get this straight.. I need a intermediate shaft from a 5-speed 90-93 integra and axles from a 90-93 non-abs intergra????
Crxgeek1997
Dec 19, 2017 08:58 AM
88LSCRX
May 26, 2008 02:44 PM
90civSi
Dec 7, 2006 03:52 AM
hybridpatient95
17
Aug 13, 2005 05:27 PM
SiR Inspired ED7
Apr 8, 2005 09:08 AM
