Bleeding brakes???
Old Jan 5, 2002 | 04:37 PM
ITR632's Avatar
Default Bleeding brakes???
I've never done it bfore and think i have the jist of what to do..... Could someone break it down for me so I know im not gonna be driving down the road w no brakes......Thanks in advance. Oh yeah 96 hatch
Old Jan 5, 2002 | 08:08 PM
smokin rubber's Avatar
Default Re: Bleeding brakes??? (ITR632)
are the brakes being bled or are you changing the fluid?
Old Jan 5, 2002 | 10:37 PM
ITR632's Avatar
Default Re: Bleeding brakes??? (smokin rubber)
well changing actually........
Old Jan 6, 2002 | 11:52 AM
Kataku2K3's Avatar
Take the brake fluid resovoir cap off on the master cylinder, jack up car and if you can take off all wheels and place on jack stands. Start with the front right brake, loosen the nipple and attach a hose to it and run the hose into a tin can or something of the sort. Have someone keep filling the resovoir as another person slowly pumps the brake pedal. This will run new fluid down to the brake. You will be able to see the old brake fluid filling the can up and some air bubbles may be coming out too, if so have whoever is pumping the brake pump it till the air bubbles stop coming out. Then in the middle of one of the pumps close off the nipple and take off the hose. Then do the same thing to rear left, move to the front left, and then do the rear right. Hope this helps!
Old Jan 6, 2002 | 12:06 PM
Default Re: Bleeding brakes??? (JDMspecEG6)
To keep all the air out of the system you need two things a full resivor, and proper timing between the pedal and the bleeder valve. you will need some 3/8 inner diameter clear plastic tube ( 3 feet should be more than enough), brake fluid (your first time pick up two quarts, one should be enough but) , a clear container to bleed into, box and openend wrenches ( dont strip the bleeder screws ), a turkey baster ( to empty old fluid from the resivor before the bleeding ).
before starting at each corner loosen the bleeder valve so that it can be opened and closed easily.
KEEP THE FLUID RESIVOR FULL TO AVOID DAMAGE TO BRAKE MASTER CYLENDER
proper manual brake bleeding
1. brake pedal down(not floored but regular braking pressure)
2. bleeder valve open,bleeder valve closed ( do this somewhat quickly )
3. prake pedal up (relased)
4. top off resivor
the person at the caliper should give orders to the person on the pedal. ("pedal down", open and close the valve, "pedal up"
any other Qs just ask
[Modified by smokin rubber, 4:07 PM 1/6/2002]
Old Jan 6, 2002 | 12:11 PM
If they just pump the prakes with the bleeder valve open than air comes right back in, you must open and close the valve with each pedal pump.
Is this the proper bleeding order for ITRs? just want to make sure
Old Jan 6, 2002 | 04:27 PM
Floyd's Avatar
The correct sequence for '98 and later Integras is left front, right front, right rear, left rear.
Elvis1977
Nov 19, 2009 06:47 PM
henni
Aug 15, 2009 03:56 PM
Nessal
Sep 3, 2005 06:24 PM
Silvteg95
Aug 19, 2005 10:50 PM
Jordan_4WS
Jan 20, 2003 02:10 PM
