Eagle rods. Question on bearing clearances...
Old Dec 22, 2004 | 11:51 AM
Hybrid96EK's Avatar
Default Eagle rods. Question on bearing clearances...
For all you engine builders.. I have a question... I have heard many things here regarding the clearances that should be used with these rods. The rods don't have the oil galleys in them like stock ones.. So I assume additional clearances may be needed. Eagle gives a "General" guideline of .002-.003" on the spec sheet.. But says clearance will vary based on application. I have heard using stock clearances will be just fine, but have reason to believe that will lead to oil starvation. Can anyone here tell me what clearances they have used with these rods that they KNOW works?
Old Dec 22, 2004 | 03:51 PM
Rocket's Avatar
Default Re: Eagle rods. Question on bearing clearances... (Hybrid93Eg)
Use the high tolerance of the OE new spec listed in the helms.
Scott53092
Apr 16, 2014 12:27 PM
94preludeguy
Apr 24, 2010 08:39 PM
Mr. Self Destruct
Mar 2, 2005 03:09 PM
EKB18BPR3
Oct 30, 2004 09:30 AM
