fixing my ancient Linde arc/tig
Old Dec 22, 2004 | 09:35 AM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
Default fixing my ancient Linde arc/tig
ive got a pretty heavy duty, very old Linde Tig. pretty sure its a 300A, monsterous machine. works well but when the selector is set for pedal heat control, it barely arcs and doesnt seem to have any range of adjustment. set to panel, it works fine with the heat ****, but ofcoarse, is limited.
the pedal consists of no more than 1 switch and one potentiometer, or perhaps theyre called rheostats. the pot seems to be working, as it varies resistance from about 3-9.. i should go double check what scale i had the meter on now that i think of it.
anyways, inside the welder there is continuity to the back of the plug, its reading the same resistance change as the pedal cord outputs. the double throw 6 pin selector switch appears to be okay but then again i have no schematics or knowledge of what should be where in this welder, and the components in there look like they could give me a pretty good zap if i get too nosey.
im clutching at straws, but do any of you oldtime fabbers have any ideas or suggestions? perhaps the resistance range on my pedal is too small?
thanks in advance.
Old Dec 22, 2004 | 10:12 AM
toolowsol's Avatar
Default Re: fixing my ancient Linde arc/tig (mike_belben@yahoo.com)
I'm guessing it is the pot, usually they go from ATLEAST 0-100ohm, usually higher, I would replace the pedal assembly and try again.
Old Dec 22, 2004 | 12:25 PM
thanks, ill check into that.
Rocket09
Honda Civic (2001 - 2005)
Sep 15, 2018 12:02 PM
EgHatchy96
Jul 7, 2013 12:09 PM
striker5661
Mar 26, 2012 05:39 PM
cats_on_ice
Jul 15, 2006 05:36 AM
kjou2001
Jun 3, 2004 03:24 PM
