JDM Frontend Conversion Question...
Well, I pretty much have my frontend completed and had a curious question running through my mind...
Below is a picture of the radiator support I got with the conversion. As I heard you only need to change the uppper piece for the conversion.
However, Will I be able to "Bolt" the Re-Bar (pic of re-bar below) to the usdm bottom portion of the Radiator Support, As I am only replacing upper portion of my Rad. Support.
Have any of you done this and were still able to mount the Re-bar with no problems?
Thanks for any help you can provide
Here is the Radiator Support i have
Here is Re-bar
Here is Re-bar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humping_dragon »</TD></TR><TR><TD CLASS="quote">yes you bolt the jdm itr re-bar to the usdm frame rails</TD></TR></TABLE>
I concur
I concur
however, you have the option of using the USDM re-bar as it is bigger/stronger. there was a write-up, but i think it has since disappeared. try a search though.
yeah you can run either the usdm rebar or the jdm one still. for the usdm you have to put 2 little notches in the bumper and redo the mouting tabs on the bumper supper bar. the jdm rebar will bolt on just fine.
risiah05
14
Nov 17, 2003 04:10 PM
guyuenvy
Jun 20, 2001 12:24 AM
