FS: bunch of crx parts/5 lug odyssey rims/gsr axels/shiftlinkage and misc
Old Dec 22, 2004 | 02:43 AM
JohnnyEF's Avatar
Default FS: bunch of crx parts/5 lug odyssey rims/gsr axels/shiftlinkage and misc
Make offers
FS: 5 lug odyssey rims fits type R (blackies) 15 inch rims
FS: new exedy stock clutch disc for the 90-91 1g b16a integra
FS: autometer oil pressure electrical sender unit only no gauge
FS: ZC oil cooler with center bolt
FS: brand new 88-91 crx shift boot
FS: Three 13inch civic rims with tires and are bald
FS: 88-91 crx si front mud flaps
FS: 88-91 JDM crx fuse box inside of engine bay
FS: 88-91 crx splash gaurd I believe its driver side says L on it
FS: 88-91 crx starter from autozone low mileage
FS: 88-91 crx si driver and passenger side axels.
FS: 88 crx si motor mounts and brackets
FS: 88-91 crx si front upper shock hats
FS: 88-91 crx si upper and lower heat shield
FS: 88 crx si front suspension fork
FS: 88 crx si big metal ecu cover
FS: 88-91 crx stock d series header upper portion 4-2-1
FS: 88 crx si cluster cover
FS: 88 crx si defrost button
FS: 90-91 crx si cluster cover
FS: 90-91 crx si hazard switch button
FS: 88 crx hf gauge cluster parting out temp and gas gauge
FS: 88 crx si dimmer switch
FS: 88 crx rear speaker mount bracket
FS: 88 crx si passenger and driver interior pillars
FS: 88 crx si dome light
FS: 88 crx fuse panel cover inside of car
FS: 88 crx driver and passenger sun visors
FS: 88 crx main relay
FS: 88 crx si upper timing belt cover
FS: 88 crx si winshield fluid resivor
FS: 88 crx si radiator fluid resivor overflow tank
FS: 88 crx si blower the one under the dash
FS: 88 crx si driver side engine bracket timing belt side
FS: 88 crx rear tranny bracket
FS: 88 crx rear view mirror
FS: 88 crx si front calipers
FS: 2 88 crx si fuel rails
FS: 88 crx si clock
FS: 88 crx rear hatch no wiper
FS: 88 crx si map sensor and two other tiny canisters sensors related to smog
FS: 88-89 crx hf tachometer
FS: 1g b16a intake cam
FS: b16a crankshaft
FS: 4 1g b16a injectors
FS: 4 b16a rods
FS: b16a throttle body minus tps sensor
FS: b16a engine block water coolant pipe and peice that holds the thermostat
FS: b16a intake and exhaust cams with gears
FS: b16a main bearing caps with bolts
FS: 1g b16a intake manifold complete with injectors, fuel rail, and throttle body
FS: 1g b16a downpipe and upper portion of header
FS: b16a used water pump
FS: 1g b16a fuel rail
FS: 95 GSR fuel pressure regulator
FS: 86-89 integra ZC oil pan
FS: 86-87 integra ZC valve says HONDA on it in big letters painted blue
FS: 95 LS driver side engine bracket timing belt side
FS: 1g b16a engine bracket timing belt side
FS: 95 Ls alternator brackets
FS: 94+GSR upper engine mount driver side
FS: 94+ gsr axels new OEM from honda
FS: 1g b16a lower timing belt cover and inner timming belt cover
email me at johny5w64@aol.com with any questions or PM me
Old Dec 22, 2004 | 06:12 PM
JohnnyEF's Avatar
Default Re: FS: bunch of crx parts/5 lug odyssey rims/gsr axels/shiftlinkage and misc (JohnnyEF)
BUMP TTT
Old Dec 23, 2004 | 12:37 AM
JohnnyEF's Avatar
TO THE TOP BUMP
Old Dec 23, 2004 | 12:49 AM
rhdef8's Avatar
bump for a fellow EF guy
Old Dec 23, 2004 | 12:58 AM
rhdef8's Avatar
Default Re: FS: bunch of crx parts/5 lug odyssey rims/gsr axels/shiftlinkage and misc (rhdef8)
bump again
Old Dec 25, 2004 | 11:22 PM
JohnnyEF's Avatar
bump to the top ttt
JohnnyEF
Aug 18, 2004 09:29 PM
JohnnyEF
Aug 6, 2004 11:29 AM
JohnnyEF
Jan 14, 2004 07:17 PM
JohnnyEF
Sep 28, 2003 05:06 PM
JohnnyEF
Jul 23, 2003 06:57 AM
