Wilwood Big Brake Kit CRX
Hello,
I have a Honda CRX 1991 V-TEC (German Typ EE8) 150 PS.
What thinks you over the Wilwood brake (12,2" rotors with 4 piston calipers)??
I have the 262mm OEM Rotors ,no dirkte brakes for crx gives from wilwood ,but it is to fit of integra!!!can their that confirm???????
The wilwood partnumber: 140-6163-D
Thanks,
Nico
Thanks,
Nico
what? i have found me a front kit from Wilwood on http://www.fastbrakes.com
im sorry i coudl not understand what you were saying. You want a big brake right? Do you want 11" rotor or larger? You could do the Integra Type R caliper and disc upgrade. Legend calipers and NSX calipers are 2 piston. and will work too
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX RACER »</TD></TR><TR><TD CLASS="quote">Hello,
Thanks,
Nico</TD></TR></TABLE>
i have the 12.2 wilwood kit, which is not installed yet, as it requires bigger caliper space.
stan
Thanks,
stan
Hello,
I will the 12,2" Brake kit from wilwood.
Have the OEM 10,2"(262mm) Brake in CRX.
Is the brakes in integra directly as in the Crx????
I think that the wilwood partnumber 140-6163-D ,the correct is. or???
Is the Brake kit from willwood good??(Quality..brake..)
Thanks
Nico
Thanks
Nico
if your car has 262 MM brakes stock, then you will need the 262MM wilwood kit which is for the integra, the difference is only in the bracket, which can be purchased separately.
i consider the wilwood kit to be one of the best on the market.
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">I called wilwood directly about that kit a while back.
They said 16" wheels clear.</TD></TR></TABLE>
MOST 16" will, Kosei racing senekas do not due to their deep dish.
supposedly TDR pro 1 and TDR pro2 in 15" do fit, i'll know in about one week.
stan
stan
Hello
@Stan Have you a wilwood partnumber from the bracket???
Have you also the 262mm stock brake??
It goes not with the bracket of integra???
Thanks,
Merry Christmas
Thanks,
Merry Christmas
The Ace
Jul 3, 2004 11:42 AM
CRX_RUS
May 4, 2004 11:45 AM
