88CRX SI motor into a 94 Civic DX how?
Old Jan 5, 2002 | 02:54 PM
import_racing's Avatar
Default 88CRX SI motor into a 94 Civic CX how?
What do i need to do in order to put an 88 CRX SI motor in my 94 Civic CX? I have the CRX Motor out, and I am waiting on info before I pull out the motor in my 94 DX. Please help!!!
[Modified by import_racing, 12:19 AM 1/6/2002]
Old Jan 5, 2002 | 03:14 PM
vsual's Avatar
Default Re: 88CRX SI motor into a 94 Civic DX how? (import_racing)
What do i need to do in order to put an 88 CRX SI motor in my 94 Civic DX? I have the CRX Motor out, and I am waiting on info before I pull out the motor in my 94 DX. Please help!!!
are you buying the 88 si motor?? if you are how much? just curious. its not worth it. if your getting it for free.....give it a try.
Old Jan 5, 2002 | 03:15 PM
McD's Avatar
McD
Default Re: 88CRX SI motor into a 94 Civic DX how? (vsual)
If I'm not mistaken, does'nt the 94 DX engine have just as much HP as the CRX Si engine?
Old Jan 5, 2002 | 03:17 PM
Default Re: 88CRX SI motor into a 94 Civic DX how? (DX_Hatch)
My DX motor is ****, and i got the CRX motor for free. So how do I do it? Any help is appreciated.
Old Jan 5, 2002 | 03:18 PM
Damn my mix up I only have a Civic CX not a DX
Old Jan 5, 2002 | 03:41 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: 88CRX SI motor into a 94 Civic CX how? (import_racing)
To answer your question.
The CRX engine will drop right in.
However, you can only use the head and block.
you must use the Civic's complete intake manifold.
you must also transfer the Civic's timing belt side engine mount to the CRX engine.
then you need to use the Civic's transmission and all other accessories.
I did the same backwards, I put a 95 Civic CX engine in a 90 CRX.
Old Jan 5, 2002 | 03:45 PM
vsual's Avatar
Default Re: 88CRX SI motor into a 94 Civic CX how? (Spaceballs the lunch box)
import racing see what i just said.....be patient on the post. people will come out of the blues and start imputting some things to help you out.
Old Jan 5, 2002 | 05:45 PM
IAIA's Avatar
Isn't it Illegal to put an older Engine in a newer Car?
Old Jan 6, 2002 | 02:42 AM
vsual's Avatar
Default Re: 88CRX SI motor into a 94 Civic CX how? (IAIA)
here's what you should keep in mind. you would do anything to keep your car back on the street. just like what BLOWN90HATCH said a few days ago. "DONT BE A SELLOUT". hope you get the point
KiLlInG 562
Sep 10, 2006 03:25 PM
Burntrubber87
Mar 7, 2005 11:28 AM
HottCRXracer
Feb 26, 2002 05:59 AM
