WTB cheap Camber kit for an 01 Type R
Old Dec 21, 2004 | 04:55 PM
Surfer_Sandman's Avatar
Default WTB cheap Camber kit for an 01 Type R
hey if anyone has one I'm really interested. Negative camber wear sucks...
Old Dec 21, 2004 | 07:11 PM
Utilitarian's Avatar
Default Re: WTB cheap Camber kit for an 01 Type R (Surfer_Sandman)
I'll sell you mine for $25 + shipping. PM me.
-Matt
NC
Old Dec 21, 2004 | 07:16 PM
Mugen Mike's Avatar
Negative camber has very little effect on tire wear. It's toe you need to be concerned with.
Old Dec 21, 2004 | 07:20 PM
MR5sARECOOL's Avatar
Default Re: WTB cheap Camber kit for an 01 Type R (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surfer_Sandman &raquo;</TD></TR><TR><TD CLASS="quote">hey if anyone has one I'm really interested. Negative camber wear sucks...</TD></TR></TABLE>
When was the last time you had an alignment?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">Negative camber has very little effect on tire wear. It's toe you need to be concerned with.</TD></TR></TABLE>
Exactly
Old Dec 21, 2004 | 07:24 PM
migs's Avatar
Old Dec 21, 2004 | 07:28 PM
p nut's Avatar
Skunk camber kits are $80 or so on ebay.
Old Dec 21, 2004 | 07:30 PM
RTW DC2R's Avatar
front or rear?
and yeah, what they said. check your toe alignment first.
Old Dec 21, 2004 | 08:19 PM
quick6's Avatar
You don't need a 'camber kit' unless you don't ever drive your car hard in corners.
As has been said it is toe that causes the problem. In this case prolly too much toe-in.
Old Dec 22, 2004 | 06:11 PM
Default Re: (quick6)
Well my tires are sitting like this
so I think I need a kit. Also I don't want to get an alignment if they can't get it in the green.
Old Dec 22, 2004 | 06:19 PM
davidnyc's Avatar
Default Re: (Surfer_Sandman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surfer_Sandman &raquo;</TD></TR><TR><TD CLASS="quote">Well my tires are sitting like this
so I think I need a kit. Also I don't want to get an alignment if they can't get it in the green. </TD></TR></TABLE>
You can just leave it as is and just adjust the toe to 0" or 0 degrees. If the alignment machine has a problem with that, you can go into the configuration menu and change the default settings for whatever car, therefore, you set the camber to what it is in your car now, then adjust the toe, and everything will be in "green." When done, the tech can just reset the machine configuration. (At least this is what I did a few years ago, when I wanted toe out and the machine didn't like it.)
ahron
10
Jan 25, 2008 06:54 PM
hondahp21
Dec 27, 2006 12:36 AM
Flava
Suspension & Brakes
26
Jun 9, 2006 08:56 AM
DOHCRX
Apr 28, 2003 07:19 PM
xstalkrx
Apr 24, 2003 05:37 AM
