B20Z all motor
I want to swap my B18A block for a B20Z block,no Vtec head i'm going to use my b18a Head, do i have to chane anything like mounts, will my A/c an power Steering fit, my car is Integra 1991 Ls manual.
thanks
thanks
Everything should fit as long as you use all the brackets from the B18A block. And you need to switch the pillar mount from the B18 block to the B20. (Meaning the metal bracket that your driver side motor mount bolts to)
unless you have done some work to your LS head, there is no point on putting it on the B20Z's. The B20Z head would be better cause it has more aggressive cams than the B18A, and the head "supposedly" flows better, but i dunno...
val used to have a damn good non-vtec b20 setup...174 hp 151 ft/lbs to the wheels.
[Modified by 95CivicSi, 3:29 PM 1/5/2002]
95civicsi
Will the the b20z fit under the hood of the teg? my concer is the Intake manifold of the b18A will it fit the b20z head
jisatsuracer
do i need to change just the mount on the driver side , nothing else.
thanks a lot for your help
jisatsuracer
project kingLS
Dec 10, 2006 08:00 PM
89ef-b18a1
Dec 9, 2006 11:41 PM
