New to the Site not to the scene. Ls/Vtec set-up want input.
Whats up HT I have this site many times and I am a long time member of Chb.com
I have been planning on building an Ls/Vtec NA motor for quite some time and I am looking for peoples input on my plans.
Please no stupid comments. I know this site can get HOSSTILE at times.
Everyone .02 is welcome.
Hopeing to get 200+ WHP
Head
Gsr head
Skunk2 IM
Skunk2 Stage2 Cams
Ferrea Valves
Skunk2 Racing Valve Springs
Skunk2 Titanium Retainers
3 angle valve job with P&P
68mm TB (Maybe)
Block
Ls Block
Wiseco Pistons (11.5-12.1 not sure yet)
Eagle Rods
Possible resleeve to 84.5 or 85mm
Ls crank microplished and balanced (unless you guy think other wise)
Full balance and blue print of block
Everything thats is unually replaced when doin a Ls/Vtec setup water pump, oil pump, etc.
Tranny
Gsr or Type R (I have a 00' tranny that I hate so damn short)
I plan on running hondata.
Car is 93 HB Si.
Want to be daily driveable but wont be daily driven.
Hope I enlisted enough info that was a quick run down.
Please POST AWAY.
Head
Gsr head
Skunk2 IM
Skunk2 Stage2 Cams
Ferrea Valves
68mm TB (Maybe)
Block
Ls Block
Eagle Rods
Tranny
Car is 93 HB Si.
Please POST AWAY.
what kind of budget considerations do you have and what are your expectations
on power/speed/usage etc... is this a one time shot build or is it something you want to step into gradually, what is your timeline? welcome to HT
Budget isnt a problem this will be a timely build up. I would like it to be completed by the summer but I want everything done right the first time so if it takes long I wont mind.
Speed isnt really a factor I wont be seeing to much speed unless I am at the track.
I want the most HP I can get but I would like it to be able drive on the street when needed. (goin to track ect)
Car will only be driven in summer and spring. Put away for the winter months.
What do you think of the set-up so far and what do you think HP numbers might be?
200whp+ hopefully.
Thanxs for the reply
200whp+ hopefully.
Sounds like a decent motor very possible to get 200 HP out of it all depends on tuning. There are alot of people on the east coast that can tune very well. But make sure you keep your ITR tranny I think thats what you meant by I have a 2000 and it's really short. I had both a ITR and a GSR and the only reason that I used the GSR is because I imploded my ITR tranny after way to many track appearances. The GSR tranny was a peice of sh*t way to long of gears lost me almost 1/2 a second 1/4 mile............................But should be able to pull 200 whp pretty easily out of that, Good luck let us all know.............
woah. if my DC2 is running 14.6 with the GSR tranny and OBD2aECU I bet the gains with gearing my car will be substantial in accleration
ive thought of this, maybe this year I will be able to get into my tranny
GSR tranny with: 4.7 and ITR diff
3.077 ATS first
1.90 GSR second
1.458 ITR third
1.104 ITR fourth (spun to 8800ish)
0.787 GSR fifth
sorry its a bit off topic, but it excites me even more to think about gearing my ride...
3.077 ATS first
1.90 GSR second
1.458 ITR third
0.787 GSR fifth
Eg_6ness
Mar 10, 2010 09:23 AM
