B16A6 and B18C1 Block Differences
Old Dec 21, 2004 | 10:42 AM
Option's Avatar
Default B16A6 and B18C1 Block Differences
I was wondering what differences there are between these two blocks other then the fact that the B18C1 block is physically 8mm taller then B16 block. Other then that is there ne other differences between the blocks?
Old Dec 21, 2004 | 12:17 PM
onepoint6i's Avatar
Default Re: B16A6 and B18C1 Block Differences (Option)
B18C has a block girdle, B16A does not.. thats pretty much it, besides being taller
Old Jan 20, 2005 | 08:16 PM
KamiKazeEG's Avatar
u mean the difference between a B18c1 and a B16a is the tallness thus giving in a bigger stroke that makes it a 1.8. its not the bigger bore thats the difference? i thought b18c1's had 81mm bore, and b16's had sumthin smaller maybe 77mm..... let me know if thats true guys
Old Jan 20, 2005 | 08:18 PM
KamiKazeEG's Avatar
another difference is that b18c1 has oil squirters to lubricate underneath the pistons, by the cylander wall. also what about the lenghs in the rods? and the stroke of the crank? im pretty sure the b16 & b18c1 have different cranks. holla bak y'all
Old Jan 20, 2005 | 11:53 PM
DOHCtorTHRUST's Avatar
Default Re: B16A6 and B18C1 Block Differences (KamiKazeEG)
b16's also have 81mm bore... the 77mm i beleive is the stroke...
tobe1424
Mar 13, 2006 06:01 AM
S10RALLYRACER
Oct 14, 2004 05:57 PM
DefiantGSR
Feb 26, 2003 05:20 PM
Unlimited
Oct 27, 2002 09:30 AM
NA EJ1
Sep 29, 2002 02:05 PM
