Anyone Running Skun2 Spec III with JDM ITR Pistions?
Old Dec 21, 2004 | 07:26 AM
RedheadRacing's Avatar
Default Anyone Running Skun2 Spec III with JDM ITR Pistions?
I am looking at that set up. My head has been done by King and we are looking at running the Skunk2 stage III. I am just wondering if I will have any valve clearence issues. The head has been milled a few thous.
Any help would be great.....
Shawn
Old Dec 21, 2004 | 12:43 PM
Default Re: Anyone Running Skun2 Spec III with JDM ITR Pistions? (SoundBuys)
Bump.... anyone?
Old Dec 23, 2004 | 07:39 AM
Old Dec 23, 2004 | 11:29 AM
Quitripin's Avatar
from my understanding the skunk2 stage 3 cams are for compression for 12.5:1 or 13.5:1 and would not see it's true performance until the demand of compression is met.
Old Dec 23, 2004 | 12:52 PM
Micro-R's Avatar
You should have clearance. We've run this setup before and never had a issue. You should clay and measure the clearance first just to make sure your going to be safe. I think you'll be better off with the stage 1 or 2 cams instead. We did alot of dyno and track testing with a similar setup and found no gains in the stage 3 verus the stage 1 and 2. Actual the stage 1 cams did the best on the dyno and on the track. the stage 2 cams did about the same as the 1's but for the money just go with the 1's
Old Dec 23, 2004 | 05:28 PM
Default Re: Anyone Running Skun2 Spec III with JDM ITR Pistions? (Micro-R)
Cool thanks guys..... The compression on the motor right now is 12.5:1 with my headjob...... I am considering sleaving the block and going up to a 2.0L and bumping the compression to 13.1:1 - 13.5:1. So I should be able to get the performance that they offer.
Old Dec 23, 2004 | 07:07 PM
Quitripin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Micro-R &raquo;</TD></TR><TR><TD CLASS="quote">You should have clearance. We've run this setup before and never had a issue. You should clay and measure the clearance first just to make sure your going to be safe. I think you'll be better off with the stage 1 or 2 cams instead. We did alot of dyno and track testing with a similar setup and found no gains in the stage 3 verus the stage 1 and 2. Actual the stage 1 cams did the best on the dyno and on the track. the stage 2 cams did about the same as the 1's but for the money just go with the 1's</TD></TR></TABLE>
what compression did you guys had?
Old Dec 24, 2004 | 04:04 AM
Micro-R's Avatar
Default Re: Anyone Running Skun2 Spec III with JDM ITR Pistions? (Quitripin)
with the jdm itr pistons on a gsr block and head we normally saw 11.2-11.3-1 c/r. we have also run the pct pistons with stage 1,2 & 3 pistons with no clearance issues (12.0-12.3 c/r). But you still need to clay everything just incase. He may have his head milled or block decked, you never know.
1991teg
Feb 8, 2007 04:50 PM
bigz187
Jun 11, 2005 07:22 AM
IggyBcool
16
May 14, 2005 05:57 PM
streetlights
Jan 23, 2005 03:22 PM
Convoy
Nov 17, 2003 01:56 PM
